- 23 Dec 2013
- North Wales
How do you use Async Shaders? Is it already turned on?
One thing I couldn't seem to find was refresh rate setting to change from 144hz or 60hz etc?
after my freesync got stuck at 40-60 i worked out that its the windows setting (win10) that you need to change to get the refresh rate to change
Yeah that happened to me, did you look inside custom resolution? Because that has 60hz stock setting.
all i did was press virtual super resolution on and bang the freesync range changed to 40-60, but turning it off did not change it back it got stuck at that....then i found it had changed the monitor setting in windows to 60 put it back to 144 and it sorted the freesync range
Just as an FYI - Anything that Windows Display options does is not replicated in Radeon Software Crimson. You can make those changes in Windows. (i.e. resolutions and refresh rates)
So we have to use windows settings for changing hz right?
How about eyefinity?
I used eyefinity in black ops 3 in split screen mode across 2 displays but now eyefinity say there isn't enough displays to enable.
If there is no solution to this, I may have to change my card.
Hopefully it will fix my "black snow" issue in SWBF![]()
Had the same bug on my system. Yes it's fixed.![]()
