Ok once again thanks a lot for your support, unfortunately the box was damaged (I have pictures in case you need) but the laptop was sealed and ok. Needless to say that I believe you when you say the box was fine, obviously dpd did something wrong... as you can see they also messed up with the delivery...
Anyway said that, the laptop started with a critical error at the first power on, then off and on again and it started correctly, it also started a series of automated scripts the first time win started ... Not sure what was this about... Maybe some initialisation procedure installed by you
? Anyway now it's running fine, I'll keep monitoring it.
I've sent you the warranty sn as requested by email.
Thanks again
? Anyway now it's running fine, I'll keep monitoring it.I've sent you the warranty sn as requested by email.
Thanks again
coming back with bad news on my laptop, was watching movies on it the other night an noticed that my screen has really back light spots around the edges specifically done at bottom right had on my screen almost like someone is pushing their thumb on the screen from behind to cause it to be light...is this a fault with the application of screen onto frame? It gets rather annoying when image is in low light or black. Don't want to come across like an annoying prude but for a laptop thats almost 2k in price i would have thought the screen would be flawless.
