- 30 Sep 2005
which one do i need for sky fibre?
I have money burning a hole in my pocket this morning
The AC87U should still work. You just remove the sky router and plug it into the openreach modem. I've used the N-56U, N-66U, AC68U all this way before.
Thanks mate, that's pretty much what I'm finding out
Merlin firmware seems a must to install
That's £150 gone![]()
That's good.
I've just put together a new tool for getting all of the details from a sky router, you'll not need it now, but if you see someone who needs help it's available over on the Skyuser forum.
Let us know how you get on. May have been worth holding off until Friday to see if there was any black friday deals.
Also a bit cheaper here. I always check this site before a purchase.
http://www.hotukdeals.com/deals/asu...outer-ac-2400-dual-band-139-49-currys-2322626
Thanks to everyone for the help
I found a local store which had stock so I went after work and bought itthe hotukdeals voucher had expired but thanks for the link anyway
Prior to plugging it in I read some threads and people went on about having to run various things in hex, and entering telnet commands etc etc
Basically I plugged it in, uploaded the latest merlin, entered my sky username and password and bang! connected straight away
OMG! this thing is awesome
Streaming 1080p xbox one over wifi two floors up, silky smooth with zero lag. It can also remotely power on the xbox when I'm outside the network (ie: mobile 3g) which could come in handy for a little xbox playing at work![]()
Just had another total lockup of the D7000. I had just hit around 23 days uptime this time. A switch off for 30 mins and back on again and all seems well for now. Gained another 1Mb on the DS too.
Ping has started…
PING bbc.co.uk (212.58.244.20): 56 data bytes
64 bytes from 212.58.244.20: icmp_seq=0 ttl=50 time=22.012 ms
64 bytes from 212.58.244.20: icmp_seq=1 ttl=50 time=21.506 ms
64 bytes from 212.58.244.20: icmp_seq=2 ttl=50 time=22.061 ms
64 bytes from 212.58.244.20: icmp_seq=3 ttl=50 time=21.288 ms
64 bytes from 212.58.244.20: icmp_seq=4 ttl=50 time=22.397 ms
64 bytes from 212.58.244.20: icmp_seq=5 ttl=50 time=37.168 ms
64 bytes from 212.58.244.20: icmp_seq=6 ttl=50 time=55.909 ms
Request timeout for icmp_seq 7
Request timeout for icmp_seq 8
64 bytes from 212.58.244.20: icmp_seq=9 ttl=50 time=22.195 ms
64 bytes from 212.58.244.20: icmp_seq=10 ttl=50 time=21.825 ms
64 bytes from 212.58.244.20: icmp_seq=11 ttl=50 time=22.331 ms
64 bytes from 212.58.244.20: icmp_seq=12 ttl=50 time=21.649 ms
64 bytes from 212.58.244.20: icmp_seq=13 ttl=50 time=21.746 ms
64 bytes from 212.58.244.20: icmp_seq=14 ttl=50 time=22.951 ms
64 bytes from 212.58.244.20: icmp_seq=15 ttl=50 time=32.490 ms
64 bytes from 212.58.244.20: icmp_seq=16 ttl=50 time=52.596 ms
Request timeout for icmp_seq 17
Request timeout for icmp_seq 18
Request timeout for icmp_seq 19
Request timeout for icmp_seq 20
64 bytes from 212.58.244.20: icmp_seq=21 ttl=50 time=21.853 ms
Ping has started…
Request timeout for icmp_seq 0
64 bytes from 212.58.244.20: icmp_seq=1 ttl=50 time=248.474 ms
Request timeout for icmp_seq 3
64 bytes from 212.58.244.20: icmp_seq=4 ttl=50 time=21.381 ms
64 bytes from 212.58.244.20: icmp_seq=5 ttl=50 time=23.886 ms
64 bytes from 212.58.244.20: icmp_seq=6 ttl=50 time=47.589 ms
64 bytes from 212.58.244.20: icmp_seq=7 ttl=50 time=66.451 ms
Request timeout for icmp_seq 9
Request timeout for icmp_seq 10
Request timeout for icmp_seq 11
Request timeout for icmp_seq 12
64 bytes from 212.58.244.20: icmp_seq=13 ttl=50 time=21.534 ms
64 bytes from 212.58.244.20: icmp_seq=14 ttl=50 time=24.424 ms
64 bytes from 212.58.244.20: icmp_seq=15 ttl=50 time=48.026 ms
Request timeout for icmp_seq 16
64 bytes from 212.58.244.20: icmp_seq=19 ttl=50 time=19.611 ms
64 bytes from 212.58.244.20: icmp_seq=20 ttl=50 time=21.343 ms
64 bytes from 212.58.244.20: icmp_seq=21 ttl=50 time=21.283 ms
64 bytes from 212.58.244.20: icmp_seq=22 ttl=50 time=21.853 ms
64 bytes from 212.58.244.20: icmp_seq=23 ttl=50 time=25.568 ms
64 bytes from 212.58.244.20: icmp_seq=24 ttl=50 time=45.214 ms
64 bytes from 212.58.244.20: icmp_seq=25 ttl=50 time=68.594 ms
Request timeout for icmp_seq 26
Request timeout for icmp_seq 27
Request timeout for icmp_seq 28
64 bytes from 212.58.244.20: icmp_seq=29 ttl=50 time=21.497 ms
64 bytes from 212.58.244.20: icmp_seq=30 ttl=50 time=21.013 ms
Ping has started…
64 bytes from 212.58.244.20: icmp_seq=0 ttl=50 time=18.295 ms
64 bytes from 212.58.244.20: icmp_seq=1 ttl=50 time=18.389 ms
64 bytes from 212.58.244.20: icmp_seq=2 ttl=50 time=18.237 ms
64 bytes from 212.58.244.20: icmp_seq=3 ttl=50 time=18.464 ms
64 bytes from 212.58.244.20: icmp_seq=4 ttl=50 time=18.439 ms
64 bytes from 212.58.244.20: icmp_seq=5 ttl=50 time=18.056 ms
64 bytes from 212.58.244.20: icmp_seq=6 ttl=50 time=18.165 ms
64 bytes from 212.58.244.20: icmp_seq=7 ttl=50 time=18.712 ms
64 bytes from 212.58.244.20: icmp_seq=8 ttl=50 time=18.050 ms
64 bytes from 212.58.244.20: icmp_seq=9 ttl=50 time=18.313 ms
--- bbc.co.uk ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 18.050/18.312/18.712/0.192 ms
Ping has started…
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=40.982 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=60.089 ms
Request timeout for icmp_seq 4
Request timeout for icmp_seq 5
Request timeout for icmp_seq 6
64 bytes from 192.168.1.1: icmp_seq=8 ttl=64 time=3.952 ms
64 bytes from 192.168.1.1: icmp_seq=9 ttl=64 time=19.654 ms
64 bytes from 192.168.1.1: icmp_seq=10 ttl=64 time=39.996 ms
64 bytes from 192.168.1.1: icmp_seq=11 ttl=64 time=60.311 ms
64 bytes from 192.168.1.1: icmp_seq=12 ttl=64 time=3.898 ms
64 bytes from 192.168.1.1: icmp_seq=13 ttl=64 time=100.242 ms
64 bytes from 192.168.1.1: icmp_seq=14 ttl=64 time=16.461 ms
Request timeout for icmp_seq 15
64 bytes from 192.168.1.1: icmp_seq=17 ttl=64 time=50.952 ms
64 bytes from 192.168.1.1: icmp_seq=18 ttl=64 time=20.283 ms
64 bytes from 192.168.1.1: icmp_seq=19 ttl=64 time=105.988 ms
Request timeout for icmp_seq 21
64 bytes from 192.168.1.1: icmp_seq=22 ttl=64 time=79.659 ms
64 bytes from 192.168.1.1: icmp_seq=23 ttl=64 time=4.373 ms
Not really, off its OK on 2.4G but the issue is not on 5G then its either the router or your wifi device. As it was OK on the d7000 it would suggest that the latter is OK.
