Caporegime
- 21 Jun 2006
sort your diet out, do cardio and weights, simple as that really
Quick update. Morning weigh in puts me at 16 st 2. That puts me at a BMI of 29.95. That means for the first time in 10 years I am not obese (according to BMI classification). That's after going to a barbecue last night, which involved burgers and cake.
A minor moment of triumph
Onwards and downwards...
You will probably want to slow it down, losing weight too fast = extra skin left behind.
I LOVE this water weight thing. What actually is this miraculous drop in lbs of water than people manage?
Increasing the exercise load maybe easier than further calorie restriction.
Taking my running to the next level is what saw me loose a lot of weight weight and then continue to loose weight while eating more and more. Exercise pretty much allows me to eat Gargantuan proportions of my favorite foods and still loose weight.
In time you can be burning over 1000 calories a day, at that point you are really trying to prevent too rapid weight loss. And it is way more fun than cutting out more food and feeling hungry.
Your progress seems great. My only advice would be for your running you seem fairly focused on getting faster but personally I would put more focus on endurance and staying injury free. The faster you run the ore stress you put on bones, muscles, ligaments and tendons, the higher the risk of injury. It is generally considered best to do about 80% of your running at a slow aerobic speed and 20% at a high intensity, but only when you are sufficiently fit.
Apart form a lower injury risk running slower you will be able to burn a greater amount of calories in total. Moreover, many of the very good physiological adaptions occur when running slow, not fast. You build better blood capillaries, higher endurance slow twitch muscles, better cardiovascular efficiency, increased ability to burn fat for fuel, etc. All of these changes will actually make you run faster and recover faster, and run at a faster rate for further distance.
I don't want to tell you what to do but if i was you I would set a goal for like a half marathon (or 10k) in a years time and very slowly build up the miles. With good endurance then speed specific work out can become more important but will also carry much less risk when all the bones and ligaments are strengthened and adapted to the task of running.
It's still a balancing act, you cannot out train a bad diet. Believe me I've tried.
What does 1,000 calories worth of exercise look like?
If I stick the cross trainer in the Contestant Pulse Rate mode (asking it to keep me at about 167 bpm), it'll tell me I've burned 1000 calories after about 37 minutes.
Always take what cardio machines tell me with a pinch of salt though.
Running for a little over an hour, depending on wight, speed, heart rate and hills.
I was referring to Kris_90 with my suggestion to be honest.
1000 kcal in less than 40 minutes would take some doing. When using my turbo trainer with pretty accurate power-based kcal estimates and a fairly high FTP (sadly my body weight is high enough that my w/kg ratio isn't all that) I get burns closer to 1000 in an hour when performing sweet-spot/threshold intervals - and as said, that's pretty high for cycling.
In fact, some would say that these figures are high enough to take with a pinch of salt too.
edit:
Some recentish examples:
https://www.trainerroad.com/cycling/rides/2576368-Seneca-Rocks
https://www.trainerroad.com/cycling/rides/2567061-Galena
