- 10 Jan 2009
- Now live in Scotland !
Pump on and bottom Radiator now all plumbed in .
Changed the T fitting to a bitspower fitting that i trusted better .
Was meant to be a 3.5 Hard drive cover but decided i wasnt putting the 3.5 drive anywhere but the hard drive cage out of site and now its a decorative item , i have one for the SSD drive though with is the MSI dragon and looks very smart .
Gorilla tape just to hold the drain port in place while i hooked it all up , took away the rear plate as without taking it away i wouldn't of been able to put the outlet (for the graphics cards) into the mid shelf and it was very hard putting it with fat hands and short finger (the no so good benefits of having the mid shelf) . and i wouldn't of seen any leeks ,so it was away with that .
will be covering up that spare hole , me and my misjudgment as it was hitting the bottom rad so had to relocate it , and now i wont have the joy if having a straight pipe all the way up-to the the GPU's , now i have to do a few bends ,grrrr .
The RAM
i changed the cold zero motherboard tray from carbon effect to black brushed aluminium but should have just left it as now i don't like the brushed aluminum , i wasted 2 meters of the stuff as it just wouldn't go on without bubbling up and creasing so i just settled for the last sheet of it and had a few bubbles at the top but top rad will cover most of it and so will the Reservoir.
The SSD backplate that will go on to the top drive bay side .
Will be installing the rest of it tomorrow and then the dreaded acrylic bending that im really not looking forward to .
The RAM
