Hey, I was looking at buying a new monitor then realized that between the money I'd spend on a new monitor and sale of my current card I could afford a 980ti, this seems like a better upgrade seeing as I'm running a 3gb card anyway so higher Res's would have struggled. Was gonna hold out for Pascal but that'll likely be out of budget at the time.
Anyway what card would you recommend? I'm thinking of getting one with a reference PCB so I can watercool it. Want to try and spend as little as possible. Thanks.
but nearly all other cards. From the 980/Ti s only the FTW, Classi and KP cards are not Ref, all other cards do use the Ref PCB layout.
