- 2 Jan 2012
- UK.
*OP Updated*
Well there is obviously a bottleneck or an optimization problem with the game code in some areas of the map as my usage goes from 90 odd % to the 50'sAnyone able to test? Gregster?
I won't be getting back in till later.
Don't the Nvidia notes state that whilst they have implemented Fallout 4 SLI support, the game also requires a patch to make it work correctly?
I seem to remember a similar issue on Far Cry 4.
359.00 to 359.06 gave next to nothing for me on JC3 with a 980Ti, still sitting fine in that 75-80 region.
Hopefully this is the case mate, however do not hold your breath.
Seems to have boosted performance for me in Fallout with a single 980ti
The release notes just say a SLI profile was added for JC3 nothing else.
359.06 just completely nerfed SLI for me, 2nd GPU wasn't even showing in NCP so couldn't enable it!
Tried two installs using driver cleaner..same result.
Went back to 359.0 and...SLI now working fine.
Not impressed.
No consolation but I have the same motherboard as you and my SLI works fine with the new drivers. Tried re-seating them?
