COD: Black Ops III
Hmm I'm not sure actually. One of the games was definitely an aimbot since it was instantly getting headshots all the time with a pistol.
The others might be running a controller for the snap aim, since they weren't getting headshots at silly ranges all the time.
Is anyone else coming across a weird amount of cheaters? The past 3 games I've played tonight all had people running some kind of aimbot.
Whole reason this game and the past ones are a waste of time, no dedicated servers means you either play with hackers or leave. :(
Never once seen from any kill cams people using this. I wouldn't let it put you off.
People saying it's some major problem are fearmongering.
Though I have seen something that might have been auto-aim in my kill cam like once or twice. Could have also been network lag, though. Either way, multiplayer is pretty BS-free in my experience so far.
This game uses dedicated servers.
I mean dedicated game servers that allow for modding, what's the point in using P2P when no one has the power to kick a hacker?
Like i said, you either play with hackers and have a **** game or you leave, there's no alternative.
Just realised there is a "mega" gobblegum section for zombies with some awesome power ups which I never realised I had! I've unlocked loads! One good one which is called Perkaholic ultra rare, gives all perks instantly :)
Edit: meh I didn't realise you only have a select few so you have to keep using liquid divinium to get more.
Also included in the patch is their attempt at a fix for some peoples (not mine) performance woes.
Take away/limit what graphics options they can use!
I had no problems whatsoever with the game, it ran over 100fps always, with everything maxed apart from shadows at medium and motion blur(eugh) off.
Now the patch has decided that no, you cannot have extra high textures running with your lowly £450 AMD Fury, silly peasant...
Bit of a joke really. Sad state of affairs.
Yeah I've seen this, I can't select high texture anymore on my GTX 960... wtf? it was running 60fps before on high!
Most of the more recent CODs are basically COD4 anyway, with a few minor tweaks (runs on the same engine, near enough).
New engine and a COD4 remake would probably be worth it, would rather them doing a new engine and WW2 however.
You can edit your config file yourself and reset it back to how you had it before, I have. Just had to make the config read only afterwards.
SteamLibrary\steamapps\common\Call of Duty Black Ops III\players\config
Bit of a lazy way of "fixing"the game if you ask me.
Defo bring back WW2. All this future stuff is driving me insane. M1 carbine, couple of frag grenades and no body armour/leaping over tall buildings/zapping bots with super powers, etc...:D
