Follow the guide. But set the memory to default speed not 3000 so 2133. Try again. I am almost certain the memory is the issue. So XMP. Then go to memory frequency and go 2666mhz. Also you can try run 3000mhz with my settings plus VL4 1.55, VL5 1.45, VL6 1.45. These are OC socket settings and help when Overclocking memory on X99 CPU. Also system agent at +0.25 can also help drive the memory high and stable.
Real shame a customer is struggling yet OCUK support is here Sat night primetime!... give that man some overtime!![]()
Thats because your not following the guide. Set XMP first p[rofile 1. This will put the mem speed to 3000 and you will be at 125 BLK with 1.25 divider. Then make other changes,
If its not doing this check the sticks did we send you an incorrect kit or something??
Finally have this up and stable close to the level 1 OC. Required BIOS F2f, and I can only manage 2750Mhz on the memory. Many failures along the way (corrupted BIOS, corrupted OS, corrupted t-shirts, and having to uninstall/reinstall the killer ethernet drivers every time I change anything in the BIOS.... sigh), but generally satisfied with the result.
Have a couple of issues, mentioning just in case anyone else with the bundle has the same:
-Windows 10 never successfully restarts. Just goes through shutdown and then hangs until I hit the reset button.
-When the system is shutdown it keeps the R9-295x humming and illuminating the room. Initially I thought it might be some cooldown cycle, but it never stops. No good for a PC in a bedroom.
-The sound output over SP/DIF is awful.
Anyone come across and (ideally) solved these minor issues?
good thing that dont take longNice one getting it stable @ 1.18V. I take it that's with 3.5GHz Uncore?
i had that as i used pg dn and pgup to set some of the manual voltage settings. turned out i set - on the ram voltage rather than + voltagetried to overclock my bundle this morning and now I get this error
NACCESSIBLE_BOOT_DEVICE - just keeps rebooting.
any idea please?
