i understand the need to have freesync work from 30hz(the lower the better), my point is it would be more beneficial to upgrade your hardware to smooth things out than rely on a monitor that has no control of your frames. gaming at 30fps is not ideal in any scenario, a freesync monitor will help, but not fix the issues and that is all.
in regards to morrowind, what are your system specs?, i know when i ran morrowind overhaul 2 or so?, on a 7970 with an i5
[email protected] i was netting around 45-50fps, but this was a long time ago.
the flickering i am 100% convinced is caused by freesync; where i commented earlier regarding a frame limiter for 144hz, i went on to disable freesync and the issues vanished. (if you can video the flicker perhaps, can it be described as the screen appearing to be bouncing up and down very fast, slightly off screen - half a mm or so? this is very noticeable for me in the newish metal gear solid with freesync enabled.
probably going a bit off-topic here (
) but my current morrowind has MSGO 3.0, Morrowind rebirth, Morrowind Comes Alive and 2 significant other npc mods, as well as others ...
I have a decent system based around an i7 4790k which my asus m/board does a seemingly good job of dynamically o/clocking to 4.6 ghz, with a r9 290. 16gb of ram, SSDs etc, etc. (I've even mucked around with ram disks - installing gothic 3 in its entirety on one!!)
The game's fine in the wilderness etc, but go to a city / town and ... well, you know.
Oblivion's the same if you do all the LOD stuff, together with the 'unique landscapes' and 'better cities' suites of mods.
All daft stuff to obsess over, of course - but I have ... and I'm not alone, believe me.
anyways ...
more on-topic - I did post about the flicker and that turning freesync off 'cured' it. So in that sense I agree freesync causes it - but I guess I'm wondering if it's more a case of the combination of freesync with certain h/ware (and s/ware) configs.
As mentioned, the fact that PCM2 played ESO (I hope I'm right in saying PCM2) with the monitor, but didn't see the flicker I do speaks for itself, on the face of it.
I wouldn't describe it visually as you do, but these things are so subjective.
I've never really got into videoing stuff like this - although I should I admit.
If I can get 'round to it, I'll post here accordingly.
