They are a pretty old unit, i had one at least 6 years ago. Very high quality psu at the time, though iirc mine had several pcie connections.It must be old as I can't find it. If it's some dated 5 year old relic with only one Pcie power then no, I personally wouldn't use it.
Iv'e sorted it...I found a second 6 pin pci-e connector in Enermax box connected it to the psu and then fitted both of them to a dual 6 pin to 1 x 8 pin adaptor that came with the card...
Then I used a 2 x molex to 1 x 8 pin and connected the other 8 pin to the 980 ti
Yes I have an 980ti
Money shot
Yep, disable vsync when benching.Just running some benchies do I disable vsync?
Can't remember![]()
It's a watercooled or air cooled versionThat looks almost identical to the MSI 6G I have! Not seen that card before is it new?
cough x34 cough![]()
Running dual molex to 8 pin on a 980TI Poseidon Platinum!!!!
Buy a new PSU you spend-thrift/cheapskate, you make no sense.![]()
Id still swap them over. Peace of mind and all that. Nice choice of card btw.
I have a 900 w corsair HM but it's in my music PC running a passive amd 6450 in the studio
I'm just to lazy to swap them over
Seems stable enough![]()
Id still swap them over. Peace of mind and all that. Nice choice of card btw.![]()
Or just change it after your molex melts, takes 980Ti out and your on a salvage mission looking to see what survived.![]()
Are the two lights by the power connectors meant to be on all the time even when I turn the PC off?
