kmode_exception_not_handled (bflwfx64.sys) windows 10
30 Apr 2014
Hi
My computer crashes once in a while due to this error
I'm sure its down to my gigabyte motherboard bigfoot driver,
what drivers can I use instead?
thanks in advance
Did you download the driver from GB or via a third party? You could try uninstalling and d/load the latest driver from GB.
Hers are some likely causes or remedies you can try.
1: Update Your PC Device Drivers
2: Repair Registry Entries Associated with Driver for Bigfoot Networks Bandwidth Control
3: Conduct a Full Malware Scan of Your PC
4: Utilize Windows System Restore to "Undo" Recent System Changes
5: Uninstall Recently-Installed Program Associated with Driver for Bigfoot Networks Bandwidth Control / Bflwfx64.sys
6: Run Windows System File Checker ("sfc /scannow")
7: Install All Available Windows Updates
8: Check for Hard Drive Corruption ("chkdsk /f")
9: Test Your Memory (RAM) for Corruption
10: Perform a Clean Installation of Windows
I actually downloaded the Drivers from GB and probably updated them from app center ,
But I did upgrade from w7 to w10 so maybe best to do a fresh install?
How do I get my code for w10, just log in using my hotmail account?
I'm pretty sure bigfoot is the problem here?
