A different router probably won't increase your speeds by much unless you also upgrade your wireless adaptor to an AC one.
I get approx 320 Mbps on speed tests with my iPad Air 2 connected to a Netgear R7000 router on the 1 Gbps Hyperoptic service.
not sure if its just a generally ***** bundled modem hyperoptic give with their service or line instability but Ive decided to buy a replacement (preferably from OCUK)
Any other advice apart from Netgear R7000 (don't really want to spend that much but if wifi etc is going to be a lot better then I will)
Tempted to replace the whole unit with a Netgear D7000 (Thread link) when it get released.
.....I get approx 320 Mbps on speed tests with my iPad Air 2 connected to a Netgear R7000 router on the 1 Gbps Hyperoptic service.
I'm thinking of switching to Hyperoptic. I download a lot of movie and tv torrents, and although none of the other ISPs I've had (sky, virgin etc) have had a problem with my torrenting, I'm a bit worried that Hyperoptic might based on what a customer rep said.
Does anyone here who uses Hyperoptic use torrents, and have you ever had a problem? thanks very much
Don't use public trackers.
Oh I don't for the most part, I use private trackers, but figured an ISP can detect torrents regardless of whether its from a public or private tracker? Mostly, ISPs don't care, but since hyperoptic is pretty small, they are an unknown
I'm thinking of leaving Sky Fibre for Hyperoptic as it's in my building and they've been spamming our mailboxes with leaflets. Can anyone give any further, up-to-date impressions?
I don't torrent at all. Internet usage is almost exclusively: Netflix, YouTube,
Is it going to save you money?
How well does the Sky connection perform?
I decided to cancel the Sky upgrade during the cooldown, because it's madness to ever be in contract with Sky and I didn't realise I'd be stuck with them for another 12 months. So currently paying £37.40 for 40MB FTTC...looking at Hyperoptic again as they offer no-contract options. Anyone else with views about their speed / reliability? I'm in London. Some of the earlier posts in this thread are not encouraging...
I am still very happy with my Hyperoptic service, have had it for almost 2.5 years now.
There has been very little downtime, only a couple of nights in the past few months but before that I can only remember one bit of downtime that was for scheduled maintenance.
Speeds are consistently high, pretty much only restricted by the site you're downloading from. Gaming latency has been decent too.
I have been using a Netgear R7000 Nighthawk router, although newer models are available now, coverage and speeds have been very fast on tablets and phones, most of my machines are wired.
I have the main supply ethernet cable plugged into the Netgear router and then have the Hyperoptic-supplied Tilgen router plugged in to the Netgear router purely to use the VOIP phone-line.
Hope that helps!
