Does that mean I could be the first in the list with the Dell?
Lol, I had mine for two weeks before I could even use it.![]()
lol done and let me know if you want to be added for the new ROG![]()
Nice video Gregster, appreicate you making that for us mate.
Please add me to the list of GSync owners, I own a Dell S2716DG![]()
Its a PG279Qnot a PG278.........
Cheers greg, framecap on/off doesn't make a difference here, it's the same regardless.![]()
Actually, it is kind of a law of physics limitation of sorts, rather than as a bug.
There is no easy workaround other than reinventing the 3D rendering paradigm to permit easy driver/hardware-side lagless framerate capping which is otherwise not easily possible.
- External framerate limiters of any kind adds lag in current 3D architectures.
- Internal framerate limiters can successfully avoid this lag.
Frames should be throttled right before input reads, and BEFORE rendering, not after already rendering, which is what external framerate limiters do (e.g. NVInspector, driver capping, VSYNC ON capping, GSYNC limit hitting). You have lost the lag battle if you already rendered the frame and then is forced to wait on presenting the frame. Game developers need to allow an internal method of frame rate capping, for full control over lag, without being forced to wait by external limiters after presenting the frame.
Only the appearance of the lag at, say, fps_max 143 (during 144Hz GSYNC) can legimately be called a potential issue. It can be improved so that there is no lag penalty when you use an in-game framerate limiter closer to Hz. But once an external limit is hit -- you yield game engine control of lag -- when something outside your game forces frames to wait.
Appreciate being added Greg picked up my Dell S2716DG during the Black Friday sales.
Havent had time to tweak it properly yet so its just out of th ebox set up wise, lookin forward to tweaking more over the xmas downtime![]()
Just realised my horror is still on post 1 -
please remove this disgusting piece of junk from post 1. Thanks
Acer Predator XB280HK - Varkanoid
On another note I've got a PG279Q burning a hole in the floor next to me at work waiting to try.
Bit apprehensive whether I got a good one or not.
So hopefully this can replace it.
Ta for the vid, same settings ive been using myself. But have decided to remove the frame cap i have been using, (135). 143.5 will be more than enough for what im playing.ArghhhhhhHHHHHHHHHHHHHHHH
And yer, I did make a mistake![]()
