 - 7 Sep 2013
should i get ps4 or xbox
mainly gonna play cod
ive had ps3 before
ive had ps3 before
I'd say PS4 simply because the controller isn't stupid and that's what I've always had.
As usual with these threads, my generic advice is usually:
- Check the exclusives for each console, pick the one you like the look of the most
- Which console do most of your gaming friends have
That being said I believe PS4 gets something earlier with COD, map packs or something? So if COD is your main game, PS4.
You're joking, right?
Sort of.
I have both but I just can't get on with the Xbox controller at all. Not quite sure why one thumb is higher than the other. PS4 controller is perfect.
Sort of.
I made the switch to PS4 this time round and one thing that I miss about the 360 is the controller. PS4 pad is ok but the thumbstick location isn't as good as Xbox.
But I'm weird as I thought the N64 controller was excellent!
Ps4 has better deals, is cheaper and more powerful. It also has a new model/chassis which is silent, the internal hard drive can be upgraded in 2 minutes.
The only thing in favour of the xb1 is cheaper online service, exclusives like halo, etc.
I have both and my ps4 sees like 99% usage compared xb1.
