It's because your fps are 293. The monitor can only handle 144fps max. VSync will prevent your graphic card to calculate more than 144fps.Im experiencing horizontal black lines randomly while playing a game on this monitor.. vertical sync solves this issue, what is the cause of this?
I had some serious issues with CS:GO while using the Crimson driver. I think this combo is bugged currently.Im experiencing horizontal black lines randomly while playing a game on this monitor.. vertical sync solves this issue, what is the cause of this?
Also sometimes it seems like a big sqaure moving and then dissapearing the black lines are flickering randomly and not att all times, its every random...
HDMI works fine..
This is the issue im currently having..
Finally this monitor is back on stock in my country.
So what's the current verdict on the monitor? Is it worth the 300€?
Does the fixed version work as intented? As in 144hz overdrive freesync?
