- 14 Aug 2015
Protection is always good. Really digging my GTX970 Xtreme![]()
Cool. What colour do you have it set on?
Video doesn't work for me.
Embedded wasn't working for me either so I put the link right below.
Any thoughts?
Gamers, what is your deepest fear for your GPU
So they conformaly coat the PCB? Easy to do yourself on any PCB.
It costs next to nothing to do to a PCB except minimal time, graphics card would take about 1 hour from start to finish depending on the type of coating.
Yes, learn to embed
Put that inbetween the Youtube tags
vf0NWc-aHQM
Great idea and so long as it isn't overly expensive, I would think about going for one. I also have a reverse case and normally watercool all my GPUs but with my Titan X, I just couldn't be bothered.
Will deffo keep an eye on this for the future though.
Awaits a snidy rep reply![]()
I've either been lucky or high end gear is already quite well protected, had water leaks on both a gpu and motherboard, nothing happened to either apart from needing a good wipe down.
That said if this pre applied protection provided warranty coverage in these circumstances I would see it very appealing.
As for doing it your self, good bye warranty.
I wasn't having ago, just pointing out that for us willing to modify its an easy thing to do.
Be interested to see what spec stuff they are using. MIL spec or something else.
