Problem i have is getting the network drivers for that mobo. I will try again though.
So, i can download the Win 10 Pro onto a DVD, boot from that and insert my Win 8 pro key?
Exactly.
Without doing an 'upgrade?'
New (2nd hand) laptop up and running I think.
But I don't get activation. The win8.1 which was in there wouldn't activate, win10 upgrade wouldn't work, and wouldn't accept any of my spare keys.
So got media creation tool, booted from USB, and it's activated from the bios stored serial. Which is same as the win8.1 which wouldn't activate.
However what does a yellow star mean, both graphics card and media storage have it next to them. It's not the exclamation and properties say they are working fine.
Just tried to upgrade my gaming PC to Win10. What an utter fail! Got stuck on the "We'll be ready soon" screen for about 2hrs. So I just rebooted my machine.
After this, while it did boot into Windows, my mouse was not working, my keyboard worked to an extent. I could hit the Start button on my keyboard and it would bring the menu up. But it only did this once. Not all the apps started properly.
In the end, I gave up and put it back to Win 7 which didn't take long at all. Think I will stay with Win 7 for a very long time and will do a fresh install of Win 10 when I can purchase a key that isn't around £80 or so. I have downloaded the Win10 from the Microsoft website onto a USB stick. So when I feel the time is right, then I will upgrade.
I guarantee you will have better results.A lot of the issue seem to come from the upgrade.
I fresh installed windows 10 originally then fresh installed the fall upgrade and have had no problems.
Use the media creation tool and give it another shotI guarantee you will have better results.
