Recently Bios engineers at Supermicron figured out how to unlock BCLK overclocking in non K SKU Skylake CPU. This was followed by equivalent Bios for certain boards form ASUS and ASrock.
On Skylake the BLK clock is not linked at all to PCI X Frequency, SATA Devices and USB for example so what ever BLK you use these remain at a Constant 100mhz so no information corruption or drive degradation can occur.
The choice of the gamer has always been i5 K sku as it has both the clock and cores to play all the games to the max....... So lets make i5 performace cheaper............ and faster!!!!!
This in mind I started testing i5 6400K CPU to find what overclocking could be achieved and the performance of that OC so I could bring out a soft bundle which I support through the forums offering amazing bang for buck.
On all CPU I tried on both the air cooler supplied with this bundle and with AIO 120mm rad water cooler upgrade I could do 4.4ghz Core and 4.4ghz Cache with 2600+mhz DDR4 memory speed. So I can confidently warranty an OC on this bundle upto 4.4ghz. At this speed the bundles performance is exactly the same as an 6600K overclocked to 4.4ghz with 4.4ghz Cache. Further more all my CPU could reach 4.5ghz Core 4.5ghz Cache and 2666+ mems. This OC is not guaranteed but should be attainable for many end users with a couple of extra changes in Bios.
Pics of the Rag
SO here are the benching Results of the bundle at 4.4ghz
Some stability testing with 1hr Real Bench
Cinebench results
And now instructions on how to overclock your buncle..........
First download the necessary Bios from here:
http://overclocking.guide/download/asus-z170-e-non-k-oc-bios/?wpdmdl=1856
Extract and put the file on USB pen drive.
Reboot and hit delete to enter Bios.
Press F7 to go into Advanced mode
Scroll Right to Tools Tab and Down to EZ flash 3 Utility, Hit enter.
Select update via storage.
Then select your USB drive from the list and the bios File you copied to the Drive.
Hit enter to select, Enter to read the file and then enter to flash the Bios.
This process will take a couple of minutes and your system will reboot several times as the MEI is also updated. Dont power down during any part of this update.
If you can't update via bios use the method detailed here:
http://overclocking.guide/flash-back-older-bios-asus-z170/
Once complete go into Bios again press F7 and set up as the following screens.
Once set hit F10 and enter to save the settings and exit.
Check in the bios that temps are fine. With experience I found upto 1.4v Core is totally fine on this CPU with the coolers in this bundle. Now test for stability with Real bench or similar and your games. If your stable leave. If not bump Vcore slightly and retest each CPU is different needing 1.28-1.38 for 4.4ghz.
For those wanting to push further try these settings below for 4500mhz.
Stability Testing at 4.5ghz
Ok so whats the downside of this crazy performance. Not much really but I must mention.
1) You have no power saving so the CPU runs full speed all time. BCLK overclocking like this means no speed step. An i5 Skylake is burning almost zero power anyway but I should mention.
2) Temperature monitoring with progs like Core temp is disabled so you need to use HWmonitor or the software provided in the motherboard bunble if you wish to check temps. This is ofcourse not the most accurate but does give an idea and like I said previously this i5 is putting out very little heat even with 1.4v and Prime its well under TJmax on Air cooler. Ofcourse the CPU will still throttle and shut down the system should cooling ever become an issue. But in my teating the headroom in terms of cooling was large.
3) IGPU is disabled.
4) updating the CPU microcode via BIOS update or software may effect the ovreclocking of this bundle. So once installed CPU microcode on provided BIOS should remain the same.
Finally why did I pick the other components besides the i5 CPU.
1) The ASUS Z170 -E motherboard was picked as its a low priced Z170 solution which is still feature rich and very solid when overclocking.
2) The Kingston mems as quite frankly Kingston are the don of DDR4 and allow for real OC headroom and stability.
3) The Brocken cooler I picked as it offers truly great cooling on a budget, is very easy to install and the fan is quiet and does not obscure any dimm slots.
4) Finally I included the AIO as an option in 120mm as this offers a silent and solid upgrade to the standard Brocken cooler should the customer require better temps and even higher OC headroom. At 120mm it also fits in almost all cases without issue.
5) Thermal Grizzley TIM simply the best and 1g sizing as perfect for a couple of applications on a CPU mount.
This Bundle is available now at the following link: https://www.overclockers.co.uk/detail/index/sArticle/59177
For a limited time its also discounted and we are offering with free shipping.
PLEASE INSTALL YOUR OS BEFORE FLASHING THE NEW BIOS AND OVERCLOCKING.
If your a gamer and want 6600K and BETTER performance for LESS MONEY !!this is bundle for you!!! SKYLAKE game smashing, Performance Thrashing not ear BASHING!! Elite tier price Crashing Bundle!!!
ADDED my Bios profile:
Those having issues overclocking this bundle. Flash 050 Bios.
Then if you wish use this profile by placing on USB stick and applying in Advanced Bios setting / OC tools / OC profiles.
https://img.overclockers.co.uk/media/unknown/i54400.cmo
Only this profile is needed nothing else if u go that way to OC
Here are the instructions for mounting the cooler:
Parts laid out!! (PICS = slight RAG TAG... due to my camera phone and marketing team being at Iseries)
Retention ring hooked in.
and secured with clip.
Place the backplate on the back of the motherboard with the holes through the mounting holes on the board.
Screw the mounting post into the backplate.
Place the CPU block head over the mounting holes on the bracket. The inner holes are for this socket.
Screw down all 4 thumb screws one twist on each screw at a time until finger tight. Attach the pump!!
DONE!!!!!!!!!!!!!!!! Any one have any questions about this guide please contact no one..... or moan for no reason!!
Pics of the Rag
Cinebench results
) id say not really worth it. The gains arent that signifigant. In games im finding pretty much zero difference between my previous 4790k @4.7ghz vs the 5820k in sig at 4.5ghz. The haswell E runs much cooler though, 64c max as opposed to 75c max. Same cooler and fans and both chips using circa 1.300v.
