** FREE DELIVERY ON MOST GAMING CHAIRS TILL 2016 - NOW WITH FREE DELIVERY ON YOUR ENTIRE BASKET!!**
OcUK Staff
26 Nov 2014
Stoke
That's right, until the beginning of January, nearly all Vertagear, AKRacing and Arozzi chairs are available with free delivery, even ones on promo! These are heavy items so it represents a nice saving. Please be aware that if you add anything else to the basket it will still charge delivery for these items, so if you want anything separately, best to do it in two transactions. Turns out if you buy a chair it's free delivery on the entire basket so even better! Here's a few highlights below -
Vertagear Racing Series S-Line SL2000 Gaming Chair - White/Blue Edition @ £189.95 inc VAT
A combination of form and function, Vertagear’s SL-2000 series focus on ergonomics, design, and functionality. Designed to give wide range of adjustability that gives gamers the best comfort and support in every gaming position for extended period of time. High backrest is designed to provide neck, shoulder and lumbar support.
Adjustable seat height
To prevent repetitive stress, having the correct ergonomic posture is important when seated for a longer time. Seat adjustability makes sure every type of user from different heights can adjust the chair to their unstressed posture. Good range of height adjustability to ensure you are at the optimum angle in relation to your desk.
Adjustable armrest
Cushioned and contoured to the shape of the arm with adjustability in height gives support to the gaming arm and prevents repetitive stress.
Adjustable back
Features independent back angle option. An angle-adjustable backrest to help you adjust your sitting position throughout the course of your gaming experience (up to 170 degrees).
Elegant Exterior
The SL2000 is made of high quality PVC leather, which makes it extremely durable and gives the chair a luxurious look. This material is easy to clean and maintain due to it’s stain- and water-resistant characteristics.
Comfort Padding
The SL2000 padding is made of high densed foam, which adds great support and seat comfort to the chair. The open-cell breathing structure, makes sure that heat arised from the human body temperature won’t get trapped inside. This gives great comfort to the user even when seated for extended period of time.
Solid Structure
The SL2000 is constructed from a steel frame that assures a solid structure. The aluminum alloy 5-star base keeps the chair solid, stable and lightweight. Assembled with a Class 4 gaslift, iindicates for better durability and ease of use. Our Class 4 Gas Lift has thicker walls to accommodate the higher pressure and stability.
Tilting feature with adjustable resistance and locking system
Our adjustable tilt tension mechanism allows you to increase or decrease the tension by easily turn the knob to match your body weight. This allows you to rock comfortably, without heavy pushing, reducing muscle fatigue.
Extra accessories
Additional neck support cushion and lumbar support cushion is included.
Soft-glide Wheels
Wheel is formulated for a quieter operation and greater resistance to foreign objects and debris.
Specifications
- Overall height (incl. base): 1280 - 1360 mm
- Width backrest (shoulder): 555 mm
- Width backrest (lumbar): 290 mm
- Width seat: 370 mm
- Depth seat: 540 mm
- Material(s): Steel (frame), High density resilient foam, PVC leather, Aluminum alloy(feet)
- Max. Load: 150 kg
- Colour: White/Blue
- Model: VG-SL2000
- Net Weight: 20 kg
- Gross Weight: 24 kg
- Package dimension: 880 x 400 x 680 mm
- Warranty: 2 years
Only £189.95 inc VAT.
ORDER NOW
AK Racing Nitro Gaming Chair - Orange @ £209.99 inc VAT
All AK Racing seats come with multiple points of adjustability so that you can tailor the position of the seat perfectly.
Features
- Colour: Orange & Black
- Quality upholstery material. NITRO series uses PU Leather.
- Metal Construction: Each seat has a sturdy metal frame.
- High quality, comfortable hard foam, not prone to deformation over time.
- Adjustable Armrests.
- Adjustable Back Angle: 180-degree backrest adjustment allows you to adjust it to your needs.
- Adjustable tilt, height and back.
- Reinforced wheels: designed not to scratch hardwood or laminate floors.
- Very Strong Metal base with class 4 gas lift support up to 150KG.
- Cushions Included for optional lower back and head/neck support.
Dimensions
- Shoulder Width: 540mm
- Waist Width: 500mm
- Seat Width: 370mm
- Back Height: 920mm
- Seat Length: 560mm
- Seat Height: 500-420mm
- Armrest Heights: 340-270mm
Only £209.99 inc VAT.
ORDER NOW
Arozzi Enzo Gaming Chair - Red @ £104.99 inc VAT
The Arozzi Enzo is one cool gaming chair. With its racing inspired look and high quality padding, you are guaranteed hours of gaming comfort.
The chair is made out of PU Leather, that is both easy to clean, and comfortable.The Arozzi Enzo gives you 360 degrees rotation and can be adjusted in height with the built in Gas Spring. The seat can also tilt and has a positional locking function.
Light weight construction makes it easy to move the chair around without sacrificing quality. The Arozzi Enzo is an awesome gaming chair that will look great in any gamer's room.
Features
- Colour: Red & Black
- Thick padded arm, seat and backrest.
- Ergonomic design.
- Synthetic PU leather for easy cleaning.
- 360 Degree Swivel Rotation.
- Adjustable height gas-spring, supports up to 120KG.
- Tiltable seat with lock function
- Lightweight construction for easy movement.
- Five twin wheel nylon casters.
Dimensions
- Shoulder Width: 530mm
- Waist Width: 540mm
- Seat Width: 530mm
- Chair Height: 1250mm
- Seat Length: 510mm
- Seat Height: 560-460mm
- Armrest Heights: 300mm
Only £104.99 inc VAT.
ORDER NOW
I like being sat on my arse all day long as it is.. with one of these chairs I would just be compounding my laziness for sure.
Great deal though.
Considering less than 200 fit in a container, 11 the 13 we've sold so far of this particular chair is fine by me :) Add in the other chairs sold so far and we're not far off 500!
Tempted by the the Vertagear SL-5000 on today only, but sad to find out I'm not big enough to best fit in it.
Currently on a DXracer Formula and its just the right size for me. Shame the SL-5000 design doesn't come in the size of the SL-2000 series :(
