Any ideas?
Bill Gates retirement holiday snaps?
Any ideas?
Internet I would guess.
Pretty dangerous if they are being streamed from somewhere online even if its from MS's servers... someone sometime is going to be unable to resist the urge to put something inappropriate on there.
Any ideas?
does ctrl prt scr not work
Windows Key + Print Screen saves screenshots to you Pictures folder in Windows 10.
Lack of ability to take properly manual control over Windows updates is utter ******* muppetry.
There should be something that allows you to set windows update to only install/download when connected to a power outlet.^^ hah yeah - its seriously poorly thought out on a tablet... trying to shutdown on low battery without being near my charger...
"Windows is configuring updates... do not turn off your PC"
Which went on for about 20 minutes until the battery died...
You guys wanna know the worst part of all this? I spent some time going through all the Metro/tile apps and uninstalling them. I then set about going through customising other things and when I got back to the start menu, those apps I uninstalled were neatly back and reinstalled! Store had redownloaded all those apps again.
The nerve.
I'm now back on Windows 7, thankfully the rollback worked great, no issues. It's as swift as ever and it feels good to be back in total control.
I have a 2 in 1 and don't really want windows update installing on shutdown when I'm using just the tablet, Battery power is sacred..![]()
If I remember though there is a way to not auto download apps from the store, just like android (play store), a setting in the store settings I think...
