- 19 Oct 2012
Hi
Does anyone know the actual max WAN > LAN throughput of the 2860?
Virgin have just enabled 200Mbps for me which is fine when using the SH2 as the router (hits just over 220Mbps) but when I put that into modem mode and then into the WAN port of the draytek I'm maxing out at ~155.
I'm leaning towards this being a draytek throughput issue although the specs suggest I should be capable of up to 300Mbps.
Thanks
Thanks
