Tories grant 18 fracking licences - all north of Leicester
yes cos we regulate things so well :roll eyes: who's going to inspect these parasitic earth killing companies? Environment agency has been cut to nothing
keep drinking the Kool Aid
Lucky the environmental agency aren't the regulator then.
keep failing to do basic research
Ground water contamination tends to come from poor well completions rather than the process of fracking - in the US it's the usual case of poor regulation and any old joe jumping on the bandwagon.
Highly unlikely to ever happen here considering the existing regulation with respect to wells/well completion from the north sea.
They were fracking wells as shallow as 60' in some areas of the US. Won't happen in the UK.
Fracking has been carried out in the UK since the 70s without problems.
And so it starts:
http://www.bbc.co.uk/news/uk-politics-35107203
Fracking under national parks is backed by MPs.
I'm thoroughly against fracking and i'm interested to see how this will affect the parks, not only through the fracking development and processing but through the traffic caused by workers and general logistics.
It won't.
The regulations regarding national parks are a farce so at last this makes them more reasonable.
No fracking under National Parks because of the alleged damage fracking may cause at the surface (which was already discussed in this thread - other than well sites, it won't). But regarding those well sites, you can drill conventional wells in National Parks (and they have been drilled in the last few years), that isn't affected by all this...
The idea of not fracking beneath National Parks was pandering to people that had no idea of the science behind fracking and had not read the multiple (UK relevant) reports on the matter. It is a win for those that want to keep National Parks as they are though, it reduces the number of wells likely to be drilled in them by removing any possibility of unconventional wells.
As mentioned it removes any problems with traffic to outside the National Park (ignoring things like Forestry Commission lorries and farmers vehicles which already operate in national parks).
And almost the entirety of the rest is caused by open pools of flowback water, which aren't allowed in the UK.
I've done it an hour. An hour in a day is nothing. Just up the road silly.
You're doing well to get from Darlo to Kielder in an hour... A68 direct, A1>A69>A68 or other route? you flew, I'm assuming? ;)
Back on topic: undecided on fracking, but damn annoyed by the Tory scum using a cheeky backdoor way of getting this through.
The HSE do quite a good job actually but lets not let your rant get in the way of the facts.
Exactly, fracking has been around for decades.
But who are we to let facts get in the way of a good ole bandwagon ;)
Unfortunately it takes a long time to plan a well. Even when you've finally decided where you want to drill to you then need to decide where you want to put the pad, work out the shape of the well, study the subsurface to check if it's possible, plan the well path, get approval from the money, contact drilling/logging/fracking contractors, write reports, write reports and presentations, talk to contractors for months to organize the best way to do it, contact landowners, write applications, send reports, presentations and applications to multiple overseeing organisations (HSE, EA etc.), consult with organisations/experts over months until they are satisfied, write planning application and send to council planning Department, liease with department and make requested changes over a few months, have public consultations, get approval from all sides for modified plans, then have council meeting where they ignore all expert advice and decline application...
Start appeal proceedings > (now) government takes it out of local councils hands after a year of council representatives ******* about.
Then have complaints by people saying its all a fix... No, the councillors ignored expert advice and recommendations from their own employees, from various government and extra government departments and multiple other sources, either because they didn't actually understand the application (quite likely) or because they weren't interested in any of it anyway (probably a mix of both).:p
That is why it's taking so long... (Which is partly what anti fracking activists want, to delay).
Fracking is going to make the Earth implode. Think about it, if we make lots of holes in the ground then blow them up with BOMB CHEMICALS then we will all get sucked into the core. It's basic science.
http://www.digitaljournal.com/news/...s-4-6-quake-caused-by-fracking/article/452682
British Columbia's energy regulator has confirmed that a 4.6 magnitude earthquake in northeast British Columbia in August was caused by fracking and is likely to be the largest fracking-induced seismic event ever recorded.
The earthquake struck on August 17, 2015 about 110 kilometers northwest of Fort St. John in British Columbia. Its epicenter was close to a fracking site operated by Progress Energy Canada Ltd. Workers at the drill site reported their pick-up trucks shook and power poles swayed by the quake prompting the natural gas production company to temporarily halt operations.
British Columbia Oil and Gas Commission, which regulates the fracking industry, had launched an investigation into the cause of the quake. It released a report last week stating that the 4.6-magnitude earthquake was caused by fluid injection during hydraulic fracturing from an operator in the area.
That's why real time seismic monitoring is a requirement in UK wells being fracked. It means any buildup to a larger quake like that one would be noticed and the frack stopped or pressure reduced, depending on the buildup.
Along with 3D seismic surveys and pre and post seismic monitoring.
It was certainly a big one for sure and really should have have happened. That said that area of BC is in a totally different stress regime than the UK (and much of Europe).
Progress Energy Canada Ltd., followed regulations and stopped operations as soon as the magnitude was known.We allowed them to continue operations with a reduced pump rate, but if another event were to occur of 3.5 or greater, you have to shut in again and we’ll try something different.
Read more: http://www.digitaljournal.com/news/...used-by-fracking/article/452682#ixzz3w9bMFKzV
Interesting to note... In the UK anything above 0.0 requires caution/reduced rates and anything above 0.5 requires the pumping/injection suspension. Which is actually quite difficult to read at surface as it can easily be below the background noise (wind, cars in the distance etc).
There is a massive police operation (helicopters, lines of police vans, road closures) current in progress not far from Chester Zoo as it appears the police are evicting the anti-fracking protesters at one of the suggested test drilling sites.
Can't believe the expense of this police operation is worth it. With global prices of oil/gas so low its not economical to drill there surely. :confused:
There is a massive police operation (helicopters, lines of police vans, road closures) current in progress not far from Chester Zoo as it appears the Baliffs are evicting the anti-fracking protesters at one of the suggested test drilling sites.
There we go, corrected your post.
Cost generally have nothing to do with policing operations. I'd hope the oil company isn't paying for it, in much the same way any other eviction shouldn't mean the property owner has to pay for police help.
Edit: http://www.chesterchronicle.co.uk/n...ton-fracking-eviction-notice-verdict-10400469 assuming it's that one they should have packed up and left the farmers land over a month ago.
