After reading some reviews on some models I see it's common for them to record in 5 minute loops so when the memory card is full the first 5 minutes is deleted and the process is repeated. What if i was to record an incident within that timeframe but it was unsafe for me to stop and then it gets deleted.
Is ther any way to have continuous recording or do any models support this. I know this would be dependant on quality of video and the capacity of the memory card.
The idea is to have (at least) two SD cards so you can remove the one in the camera immediately after the incident and replace it just in case there's another incident on your way home.
I've just hardwired my dashcam into my E46.
Took a couple of hours - was pretty easy though! What kind of power connector does the mobius use? My one uses a micro USB cable.
You could allways use the lens extension
[RXP]Andy;29016847 said:What are peoples thoughts on the "Dome D201" or are the 80X range the best ones to be looking at? As I have started to look into getting one fitted to my car.
Looks like a chunky bit of kit, apart from the suction mount is there another discreet way of mounting it?
Caught this on my Mini 0805
Fiat had right of way regardless, the UPS driver is very clearly in the wrong here.Not sure how interesting this is, but the silly bugger in this Fiat 500 didn't indicate on a roundabout and nearly got a UPS truck in their side.
Which dashcam did you go for and how did you mount it?
I've got the Mobius one which is reasonably discrete, I wanted to get it mounted somewhere it'd be hidden away but still useful, due to the curvature of the E46' windscreen, it's quite difficult
It's got a Mini USB connector for power so I'll need to get a hardwire kit and route it through the A pillar and into the roof..
This is a pretty shocking road rage incident caught on dashcam: http://www.dailyecho.co.uk/news/141...and_speeds_off_in__road_rage__in_Southampton/
Can't understand why the police are appealing for witnesses when everything is on camera.![]()
