- 19 Feb 2007
- Northampton
Here is some info from GPUZ @ idle. Memtest86 passed with flying colours.
Idle and you have 60'c+ temps
Turning off Xbox One DVR has improved the temp and memory usage.
Looking at your 3 images it's obvious why your temps are getting lower at idle. In the first one you are at full 3d clocks, in the second the clocks have dropped but they are still to high for idle and in the last one your clocks are in full idle. Your temps are still on the high side though. Something looks to be using your gpu at points heating it up.
Try having a look in task manager to see what's being used when the gpu clocks are spiking like this.
)YUP..^^
What case do you have the card in and how are the fans setup on the case ?
Also TheRealDeal the Classified turns off the fan at below 60c and takes a little time for the temps to come down to about 35c at idle, he may have been at higher clocks at the time and then went to idle so it will come down to lower than 49c (I noticed that too, just one step at a time to get him up and running right)
YUP..^^
Can you take a picture of the case inside. Also leave gpuz open and let it idle for 15 mins then state the temps. With no other programs open apart from gpuz. Your idle temps should be 35c to 40c.
Close the chrome processes and same for Nvidia experience and any other program that is not related to windows OS, eg skype, just dont close anything saying intel or driver related.
Then check the idle temps again.
Also
When you get the new PSU I would cable manage that and give it a good dusting too. Apart from that the case looks fine mate and if you are saying with case open and it's in the 50's it's something else not the case, but I would get some side fans for that case and fill up the fan areas to get better air flow.
OHHH i see something you did that is not good, dont use the same pci-e cable to power both 8 pins for the classified, use the 2nd cable to power the 2nd 8pin not the bit that comes off the single cable. Run 2 PCI-E 8pin cables to the GPU. That can cause power issues too.
