 - 20 Feb 2009
If I didn't have quite so many drives the S would tip it over the r5, but I use too much storage for it to be an option so its am r5 for me.
			Anyone with this case, would it fit a 80mm deep radiator at the front? Ive got a 280mmx80mm Alphacool monsta.
I've got one also but i think it would be a little too much with a pump and res mounted on the front of the rad, maybe 20cm too much on my setup.
Finally booked some time in to move my rig from my Coolermaster case into the S.
Tidy up this mess.
Has anyone tried fitting 3 Noctua NF-A14s in the front? I want to make sure they'll fit before buying this case.
Its a tight but they fit.
Are you speaking from experience?
I've read conflicting reports on forums, so I just want to make sure!
	Yeah i have 3 in the front of mine.
[/IMG]![]()
Noctua D15.
cheers, did you have any issues fitting it?
Its a little tricky to plug the fans in the motherboard but not impossible![]()
