- 19 Feb 2007
- Northampton
My screen flickered off and on for a second or so last night, hoping it's just a driver issue, Can't be bothered with the fuss of a faulty PSU
Bought my Asus Swift on day one and it's been perfect ever since. Very happy Swift owner![]()
I've been thinking of buying this monitor. But has a lot of the issues been fixed?
What brightness is that with? that would be borderline for me depending on how noticeable it was in normal use with moderate levels of brightness.
Every ten minutes on the dot my screen turns itself off, Says no signal then goes blank, I have all the power settings in windows set to never turn the monitor off yet when I press escape the monitor comes back on.
Anyone experienced this ?
Probably the power supply failing - though I've not had it like that - my original PSU does the opposite at ~10 maybe 15 minutes intervals where it wakes the monitor up from standby.
I half wonder if the power supplies are the actual source of so many of these monitors failing rather than the panels themselves - both of the original PSUs I've got my hands on were really nasty when put under the scope but both were also failing so it might be due to that rather than their original state.
Tbh id just suffer the hit and buy an aftermarket psu. You could end up getting a worse monitor than the one you have by getting a replacement. Shame that the customer has to resort to this though.
Mine still flickers a few times, can go days without doing so then do it two or three times in an evening. Unplugging and replugging the cable from the power brick sorts it out.
