Man of Honour
- 23 Mar 2011
- West Side
Antec 300 max cpu cooler height 170mm
1. No. The 980 Ti will probably be the same price as a 970 once the new graphics cards are out, so then you can either grab a couple of them for the price you'd pay for a single card now, or invest in the top tier tech of Pascal/Polaris. It's a generational leap, and the performance should be representative of that, however the only condition is that you're patient enough to wait until they're released.I have budget to go for SLI GTX980Ti, but with the new Pascal architecture around the corner, do I really want to invest heavily in the old?
If you are contemplating SLI or Crossfire in the future, then you should go for the i7-5930 at £469.99 (+£10 for the retail version with cooler) for the extra PCIe lanes.
The 5820K will handle SLI just fine.
But the 5930 will handle SLI and Crossfire better.
You dont need a 1000w PSU. High quality 550w is plenty.
The performance difference with two cards is so small that the extra £150.00 for the 5930k over the 5820k isnt really worth it. Ive ran dual card sli on mainstream Z77/87 and scores in benchmarks/fps in games were very similair to systems using the same cards but with the more expensive 40 lane X chipset cpu's. For 3 or more cards, yes i could see the point there.If you are contemplating SLI or Crossfire in the future, then you should go for the i7-5930 at £469.99 (+£10 for the retail version with cooler) for the extra PCIe lanes.
