- 5 Feb 2009
Cheers. I already know how and wear (intentional typo) to get it, I'm just nervous of going to any of the main factions. I understand the game warns before PNRs etc, but I realise there are quests that will not warn you that you're about to royally **** off other factions.
Can anyone tell me the best way to play out as much of the faction quest lines up until the point I have to choose? I want to do as many quests as possible without being locked out of any of them. The only line I've progressed much with is the Minutemen where I've completed Old Guns.
You can do The Institute questline until the quest to relay to Mass Fusion. Doing that will make you enemies with BoS, but you get a warning before going there. With The Institute, you can stay onside with the Railroad until you're sent to destroy them in End of the Line. You can complete the Institute quests without becoming enemies with The Minutemen, though there is an instance where you might need a speech check to avoid having to choose between them.
You can do as much as you want with The Minutemen without becoming enemies with anyone else I think, and you need to actively get banished from The Institute in order to pursue The Minutemen's specific ending. At least I never got any MM quests to attack anyone else whilst I was still in The Institute's good graces. You may have to defend The Castle from BoS pursuing The Minutemen ending, but I'm not sure what triggers that. It's after fighting The Institute anyway.
Siding with the other factions will end up with you having to destroy the Institute at some point. Siding with The Railroad will also have you take on the BoS, in the mission Precipice of War, but I think I'm right in saying you can do anything up to then safely (though perhaps the previous RR mission sets the BoS as enemies? I can't remember)
Not very sure how far you can go with BoS since I hated them from the start and only did their radiant quests and quests that were obviously side-quests once I'd got onboard the Prydwen.
I needed closure with this game after 90 hours and reaching level 58 with only radiant quests left outside the main questlines. Got the "Nuclear Family" ending. Didn't like the choices towards the end of the main storyline
(hated gunning down all the Railroad members)
