Spec me a screen protector
4 Feb 2004
Écosse
Probably been lots of threads on this so I apologise for starting another. :cool:
Got an iPhone 5 and have tried using one of those TAKTIK armoured cases to protect it but it weighs a ton and the screen sensitivity seems a little compromised too. So I think I'll go back to my gel case which protects the front but I'll need something to keep the screen in good condition. What screen protectors should I be looking at? One which is like a roll of protective film or one of these thin glass ones?
Ta.
Always used Zagg ones. Lots of options, you pay a little more than the rest but they're usually very good and the warranty service is superb. If you change your phone, **** up putting it on, chip it, pull it off, they'll replace it.
Installing a Zagg without bubbles/dust is blooming impossible though.
I've only ever messed one up and with Zagg you just send it back anyway and they replace it for you. They're not that hard if you just take care, though my last one I managed to include a cat hair in pretty much the middle of the screen....
Particularly with a case, the glass ones they do now are superb, and come with a "mount" which makes it ridiculously simple.
I'd take the toughened glass type personally, they're easy to get along with, optically clear and offer decent protection while costing very little.
