Artifacting in Windows - RIP GPU?
26 Dec 2008
Cornwall
Hey all,
For the past two weeks I've been having issues with odd artifacts occurring within Windows 10.
I find little black boxes appearing every now and then, sometimes they'll go away if I scroll down the web page I'm on, sometimes they don't, trying to highlight what is behind it to force a refresh of the section works, sometimes it doesn't.
Any ideas what I can do to identify if my GPU is dying? My warranty runs out in March, so I'd rather find out it's dying now!
What I've tried: I've tried re-installing graphics card drivers to no avail, my GPU is water-cooled and so its constantly sub 50c under max load
Images occurrences (will update as with more screenshots as it occurs):
Is that Chrome you are using? because it is know issue disable hardware accel helps some people but not all this method is worth trying as well chrome://flags/#disable-slimming-paint in address bar then press enter
Use the onboard gfx and see if its normal that way?
I'll give this a whirl at the weekend - Might switch to the GPU in my other halfs machine since she isn't using it :)
Set this on, will see how I get on
Is it artifacting in games? You could download a demanding visual benchmark like Heaven and see how your gpu handles it. Run it for a good period of time and see if any artifacts show.
