Recomend me a strap for 2 cameras
20 Oct 2002
Oxfordshire / Bucks
Hi all
Can anyone recommend me a strap for my Nikon D7000 and another one for my Sony RX100 please ?
need one for when I go to America
Thanks
Op/Tech Pro camera strap x2 if you want a neck strap. Perhaps just a hand strap for the Sony?
Peak designs slide lite, I have their larger strap for my K3 and it's ossum.
Interchangeable, so you'll only need to buy the one.
Works with their hand grip, which is another great piece.
http://www.amazon.co.uk/Peak-Design...F8&qid=1453048929&sr=8-3&keywords=peak+design
^ +1 for a Peak Designs one. Really like my one by them.
They look great, the clutch looks good to, if that will for on my RX100, ill get the slide and the clutch together
Cheers all
I have the peak design leash and slide (original skinny one) - fantastic straps and use it on my D7100
Not sure you will get the toggle through the minuscule strap hole on the RX100 though .......
ok looks like a peak designs lite for the SLR
what about my little compact ?
be nice to have another over shoulder/sling for it (as im thinking about 1 or the other not both at the same time)
any suggestions?
No probs, yes if it fits the toggles stay on the camera and then any Peak Design Strap can click on and off, totally interchangeable :)
Nope I can't do it, even with dental floss - the loop on the camera is just too small
You can see the size difference between the Sony strap string and that of the PD toggle:
Infact I had to use the dental floss to get the Sony one back in !
I suppose if you could get some parachord through and tie a loop off you could then tie the PD toggle onto that ?
Wow, that is tiny...
I thought the strap mount holes on my GM5 were small.
No probs
I suppose another option is a split ring or triangular strap lug through the gap and attach it to that
