** Edifier Speakers are BACK !!! **
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi Guys,
I have recently joined the purchasing team here at Overclockers so I needed a big product that I believe is of good quality and of a very good price. So with that in mind I would like to introduce the Edifier range as my first official launch. I feel bringing back the Edifier range will add a little more variety to the speaker section and will offer the you guys a good range to choose from whatever your needs and budget.
After a meeting with Edifier and discussing current products and all future products we were both excited to get the products back into Overclockers. The listed items are a select few of the current range that we believe will suit the market really well and especially for our customers.
We managed to have the pleasure of testing the Studio R2000 speakers in the office while playing a little bit of Project cars and they sound amazing on the stock settings. You also have the ability to adjust the bass which is just a recipe to annoy the neighbours especially on project cars as the difference on each level is immense.
The Studio R2000 were also on display at the recent Bett Show which gathered a lot of interest with in that side of the industry due to the sound quality and eye catching gloss look that the speakers have.
The whole range that we stock is listed below and I hope that we have something listed for you guys so please take a look.
Any questions please let us know.
Most of the items are on Pre-order and will arrive Monday 1st February.
Edifier Studio R2000DB - 128W RMS Bluetooth Speakers @ £169.99 inc VAT
The R2000DB are a very stylish looking set of speakers with the glossy finish and with a removable front cover to allow you to have a different look.
Delivers powerful audio for PC, gaming consoles or mini home theater applications. Connect audio devices or comsoles to the R2000DB using the RCA-RCA or RCA-AUX audio cables for versatile and dual connection options at the same time. Optical, Bluetooth and dual RCA inpits for connectivity to multiple audio sources
Astonishing sound
Not only is the R2000DB stunning, this bookshelf speaker will leave you speechless. It is an ideal speaker for computers, gaming consoles and mini home theater. Encased in MDF wooden enclosure to minimize acoustic resonance, Edifier’s speaker will produce spectacular sound.
Eagle Eye
Using newly developed 25mm silk dome “Eagle Eye” tweeters, this bookshelf speaker makes the slightest sounds clear.
Distortion in your audio is a thing of the past. The R2000DB has built in Digital Signal Processing (DSP) and Dynamic Range Control (DRC) to minimize distortion.
Function meets style
Edifier’s R2000DB has a high gloss piano finish as a touch of elegance to match your room décor.
Versatile and dual connection
Connect devices to the R2000D through optical and RCA input. You can also have more than one device plugged in at a time. Using Bluetooth you can pair your smartphone and avoid using wires.
Built-in and wireless controls
The R2000DB comes with a wireless remote for your convenience. Or use the side panel on the speaker to adjust bass, treble and master volume.
Specification:
- Total Power Output: RMS 24W × 2 + 36 W × 2
- SNR: >85dBA
- Frequency Response: 55Hz-20KHz(±3db)
- Channel Seperation: >45dB
- Tweeter Unit: F25mm Ru-Fe-B silk dome,6 Ohms
- Full Range: 5.25" alloy,4 Ohms
- Dimensions:174×289×252mm
Only £169.99 inc VAT .
ORDER NOW
Edifier Studio R2730DB - 128W RMS Bluetooth Speakers @ £199.99 inc VAT
The R2730DB by Edifier expands the Edifier Studio series with this monstrous, 2.0 system that offers a three-way Tri-amp audio solution. Besides version 4.0 Bluetooth connectivity for audio playback, the system is also armed with optical, coaxial, RCA and auxiliary line inputs that make it versatile for connection to multiple audio sources simultaneously.
The total 136 watts of output power creates deep, ground shaking bass from the 6 1/2 inch bass driver and clear treble and high notes from the 4 inch mid-range and ¾ inch tweeters.
The system utilises a professional audio processor from Texas Instruments, with sophsicated features including electronic crossover, speaker compensation and dynamic range control which are carried on in the audio DSP to make the ampilifier perfectly match the speaker system.
The front mounted bass reflex port with carefully calibrated cross-section helps to extend the low frequency effect and eliminates air turbulence at the same time.
A dedicated bass signal output is available on back panel to make it possible for connection to external subwoofer.
The MDF wooden housing keeps the speaker system thoroughly grounded for boisterous volumes whilst reducing acoustic resonance. With a wireless remote included, the R2730DB can easily switch between audio inputs and volume levels. The side-mounted adjustment panel allows users to tailor fit bass and treble preferences. The R2730DB is an iconic system, producing audio from low bass to high treble notes that is sure to impress even the extreme audiophile.
Features:
- Active bookshelf speaker with Bluetooth pairing capability for music playback
- Dual Digital (optical, coaxial) and dual analogue (RCA and 3.5mm) audio inputs for versatile source connection
- 6½ inch (178mm) bass driver, 4 inch (116mm) mid-range and ¾ inch (19mm) NdFeB tweeter drivers
- Calibrated, front mounted bass reflect port effectively extands bass response
- Professional 5 pin XLR canon type speaker connecting cable with angled connector
- Class D amplifier with DSP based electronic crossover and dynamic range control minimize system distortion
- Stand-alone bass signal output available for connection to external active subwoofer
- Multi-functional wireless remote control and side panel control on active speaker
- All MDF wooden enclosures to minimize acoustic resonance
- Universal 100V-240V power supply
Specification:
- Total power output: RMS 14W × 2 (treble) + 14W × 2 (mid-range) + 40W × 2(bass) (DRC ON)
- Signal to noise ratio: >85 dBA
- Frequency Response: 45Hz-20KHz(@+/-6db)
- Input Sensitivity: Line 1: 700 mV ± 50 mV , Line 2: 500 mV ± 50 mV, Bluetooth, OPT, COX: 350mFFs ± 50mFFs
- Input Type: RCA/Bluetooth/Optical/Coaxial
- Bass Unit: 6½ inch (178mm)
- Mid Range Unit: 4 inch (116mm)
- Treble Unit: 19 mm silk dome tweeter
- Dimensions:
- Active Speaker: 218mm x 393mm x 298mm (W x H x D)
- Passive Speaker: 218mm x 393mm x 294mm (W x H x D)
Only £199.99 inc VAT.
ORDER NOW
Edifier Studio 980T 2.0 Speakers 24W @ £44.99 inc VAT
Compact in size, the studio 980T is an efficient 2.0 solution for desktops and small spaces. With 2 RCA ports and 24w RMS they will work with any laptop or computer.
- Dual RCA inputs for connectivity to multiple audio sources
- Calibrated flared bass reflex port, in front of the speaker cabinet
- 100% MDF wooden enclosure
- Universal switching power supply
- Active bookshelf speaker system with 24W total power output
Specifcations:-
- Total power output: RMS 12W × 2 (THD+N=10%)
- Signal to noise ratio: =85dBA
- Input Type: PC / AUX
- Audio input: Dual RCA input (RCA - RCA and RCA to AUX)
- Adjustment: Master volume control, bass adjustment control
- Frequency response: 70 HZ-20 KHZ +/-9db
- Input sensitivity: PC:700±50mV AUX:550±50mV (THD+N=1%)
- Subwoofer / bass unit: 4 inch (106mm), 6O
- Tweeter unit: 13mm silk domed tweeter, 4O
Dimension: 140(W) × 226(H)× 197(D)mm
Only £44.99 inc VAT.
ORDER NOW
Edifier Studio R1280T 2.0 42W RMS Speakers @ £79.99 inc VAT
Equipped with Dual RCA inputs the R1280T can produce upto 42W RMA of audio output A 4 inch Bass driver and front facing bass reflex port ensures the bass notes are robust and rich in sound. Connect to multiple devices and personalize your listening experiences with the bass and treble adjustment dials located on the active speaker. A remote control also can be used to control the volume.
- Universal power supply (100-240V)
- Active bookshelf speaker system with 42W total power output
- Bass, treble and master volume dials located on the side panel
- Wireless remote control for volume adjustment and mute
Specifications:-
- Total power output: 21W x 2
- Input sensitivity: PC: 750mV ± 50mV | Aux: 550mV ± 50mV
- Distortion: =0.05%
- Adjustment: Volume, bass and treble adjustment, remote control
- Tweeter unit: ?13mm silk domed tweeter, 4O
- Weight: 4.9Kg Net | 5.65Kg Gross
- Dimension: 146mm x 234mm x 196mm (WxHxD)
Only £79.99 inc VAT.
ORDER NOW
Edifier Luna Eclipse Bluetooth Speakers black (E25) @ £149.99 inc VAT
Luna Eclipse comes with an Exotic design. Extraodinary sound and is Effortlessly stunning. Bluetooth pairing capability with Bluetooth enabled devices. The Luna Eclipse come with dual passive bass radiators for enhanced bass effect in each speaker. Control the Volume and Power with a wireless remote.
Roaring Beauty
Extraordinary sound has never looked better. Luna Eclipse Bluetooth speaker’s exuberant performance is contained in a distinctively elegant body, featuring smooth curves and piano finish. It’s effortlessly stunning from every angle. And the perfect accessory that completes any decor at your home and office.
Sleek Remote
A slim, easy-to-use remote control accompanies this roaring beauty. You can adjust volume and power the system on or off with the touch of a button. From any corner of your room.
Dual Bass Radiators
Each of Luna Eclipse's satellites is equipped with a ¾" silk-domed tweeter and a 3" full-range bass driver, together producing an impressive 74 watts RMS. This Bluetooth speaker also contains two 3" passive bass radiators, maximizing the bass performance.
To satisfy the most ardent audiophiles, Luna Eclipse is armed with Digital Signal Processing (DSP) and Dynamic Range Control (DRP) technologies, minimizing audio distortion even at the highest volumes. The result is pristine, vivid sound at any volume. So don’t be afraid to pump it up.
Bluetooth Capability
Luna Eclipse's built-in Bluetooth feature lets you stream your favourite music wirelessly. Pairing is easy. Simply connect this Bluetooth speaker with any Bluetooth-enabled device, like your smartphone, tablet and laptop, for a seamless and cordless listening experience. You can also connect to your audio host using the 3.5mm auxiliary input.
Touch Controls
Luna Eclipse is beautiful to look at. It’s also fun to play with, thanks to its touch-sensitive controls. Simply tap or swipe to adjust volume, change tracks, put the Bluetooth speaker on standby, and power on or off.</p>
Specifications:
- Total Power Unit: 15W x 2 + 22W x 2
- THD + N:: 10%
- SNR: >85dBA
- Input Sensitivity: 600mV ± 50mV
- Frequency Response: 50Hz ~ 20 kHz (± 6dB)
- Tweeter Unit: 19mm silk dome magnetically shielded, 6ohms
- Speaker Unit: Tweeter/Mid-range: 19mm, 4O / 4 inch (116mm) 6ohms
- Passive Driver: 3 inch
- Dimension: 122 x 212 x 222mm (W x H x D)
- Weight: 3.6Kg net | 4.15Kg gross
Only £149.99 inc VAT.
ORDER NOW
Edifier 5.1 Surround Sound Speakers S760D @ £499.99 inc VAT
Edifier 5.1 Surround Sound Speakers S760D is a ground-shaking 5.1 surround sound system that maximises your listening experience. The S760D is a 5.1 home theatre system with Dolby Digital, Pro Logic II and DTS with 3 optical, 1 coaxial, analog 5.1 and dual stereo inputs. The S760D also comes with a multi-functional controller and wireless remote control.
Enormous Subwoofer
Boasting 540 watts RMS, S760D demands its share of attention. A massive 10" subwoofer driver and twin bass radiators deliver superb bass performance. Complemented by two-way satellite speakers with 3½” midrange drivers and 1” solk-domed tweeters.
But S760's superior sound doesn't stop there. With the power booster function to enhance system volume, S760D is designed to instantly fill a large room with exhilarating sound. The two-way satellite speakers, with professionally calibrated crossovers, is equipped with 3.5-inch mid-range drivers and 1-inch silk dome tweeters.
Wired And Wireless Remote Control
No matter where you are in the room, S760D lets you stay in full control of your sound. It features a wired remote control with LCD display and a wireless control, providing easy trimming, tuning, volume and input adjustments.
Multiple Inputs
Featuring 3 optical inputs, 1 coaxial input, analog 5.1 and dual stereo inputs, S760D is a versatile speaker system for home entertainment, gaming and music, you name it.
Specifications:
- Total Power Output: L/R/C/SL/SR: 60W x 5 SW: 240W
- Digital Decoder: Dolby Digital, Dolby Pro Logic II, DTS
- Frequency Response: L/R/C/SL/SR: 160Hz - 20KH SW: 35Hz -110Hz
- Input Sensitivity: Satellites: 750mV ± 50mV Subwoofer: 900mV ± 50mV
- Channerl Seperation: R/L: >45dB
- Tweeter: 1 inch (25mm) 6ohms
- Mid Range Unit: 3.5 inch (92mm) 4ohms
- Bass: 10 inch (260mm) 8ohms
- Dimensions: Subwoofer: 367mm x 397mm x 489mm (W x H x D) Satellite: 116mm x 203mm x 160mm (W x H x D) Center: 316mm x 117mm x 157mm (W x H x D)
- Weight: Subwoofer: GB: 19kg (net), 22.1Kg (gross) | MC: 24kg (gross) Satellite + Center: GB: 11.5Kg (net), 13Kg (gross) | MC: 24.2kg (gross)
Only £499.99 inc VAT.
ORDER NOW
Edifier M1550 Multimedia 5.1 Speakers @ £49.99 inc VAT
The M1550, a 5.1 speaker system by Edifier is an efficient mini home theatre solution, or simply a speaker system for optimal surround sound. The wooden encased subwoofer provides rich sound while the volume is controlled with ease via the wired remote controller. Triple 3.5mm jacks allow the ability for both stereo input signal and 5.1 channel input signal.
Main Features:
- Subwoofer / bass unit: 4 inch (106mm), Magnetically Shielded, 6 ohms
- Midrange / high unit: 2 inch x 3½ inch (50mm x 90mm), Magnetically Shielded, 4 ohms
- Mini home theatre/surround sound 5.1 multimedia speaker system
- Wooden MDF subwoofer enclosure
- Master volume control, green indicator, stand-by option, and line-out for headphone all included on wired remote controller
- Triple 3.5mm jacks accept both stereo input signal and 5.1 channel input signal
Specifications:-
Total power output: RMS 4 x 3W + 4W + 10W x 1
THD + N (testing level): 10%
Input sensitivity: Satellites: 350mV ± 50mV | Subwoofer: 80mV ± 20mV
Input impedance: 10KO
Audio Input Type: 3.5mm Line in, Headphone jack
Adjustment: Wired remote control, volume control, mute/play button, bass control on subwoofer
Subwoofer / bass unit: 4 inch (106mm), Magnetically Shielded, 6O
Midrange / high unit: 2 inch x 3½ inch (50mm × 90mm), Magnetically Shielded, 4O
Remote control: Wired: Volume adjustment, mute/play button, Headphone jack, LED indicator light
Dimensions: Subwoofer: 158mm x 226mm x 223mm | Satellite front/surround: 68mm x 166mm x 86mm Center satellite: 160mm x 66mm x 60mm (WxHxD)
Weight: 4.50Kg (net)
Only £49.99 inc VAT.
ORDER NOW
Edifier M1380 Multimedia 2.1 Speakers @ £39.95 inc VAT
For excellent PC sound quality, look no further than the impressive Edifer M1380 2.1 PC Speakers.
This 2.1 speaker system can help you to get the very best sound from your PC. Comprising of two 8W satellite speakers that are matched with the subwoofer for great sound quality, you can expect clear and rich tones from the M1380.
The 12W subwoofer is encased in MDF with a front bass reflex port that helps to deliver great audio.
There's plenty of things you can connect the M1380 speakers to thanks to the 3.5 mm connection and RCA input, giving you ample choice. Whether you blast out some tunes from your mp3 player or immerse yourself in your favourite game, you'll be sure of the very best sound.
Specifications:-
- Total power output: RMS 8W x 2 + 12W x 1
- THD + N (testing level): 10%
- Input sensitivity: Satellites: 450mV ± 50mV | Subwoofer: 70mV ± 20mV
- Input impedance: 10KO
- Audio Input Type: 3.5mm Stereo line-in, Auxiliary input, Headphone jack
- Adjustment: Power, Base, Volume, Mute
- Frequency Response: Satellites: 140Hz - 20kHz | Subwoofer: 20Hz - 130Hz
- Subwoofer / bass unit: 5 inch (131mm), Magnetically shielded, 4O
- Tweeter unit: 2¾ inch (70mm), Magnetically shielded, 4O
- Remote control: Wired: Volume control, headphone jack, mute
- Control panel: Bass trimmer, Power switch
- Dimension: Satellites: 120mm × 151mm × 125mm | Subwoofer: 164mm × 220mm × 280mm (WxHxD)
- Weight 4.20Kg (net) / ˜5.20Kg (gross)
Only £39.95 inc VAT.
ORDER NOW
Edifier M1250 2.0 Speaker System @ £9.95 inc VAT
USB powered for all desktop and portable devices for sound wherever you go. The flat panel design allows for the M1250 to be packed and transported with ease, while the volume and power are easily adjustable when in use, via controls located on the satellite. Magnetically shielded and equipped with a headphone jack, the M1250 is a practical audio solution.
- Total power output: RMS 0.6W x 2
- Signal to noise ratio: 80dBA
- Frequency response: 150Hz - 20KHz
- Input sensitivity: 250mV ± 50mV
- Input impedance:10K ohm
- Audio Input Type: 3.5mm stereo line-in, USB, PC sound card, headphone jack
- Adjustment: Volume control
- Speaker unit: 50mm x 90mm, magnetically shielded, 4?
- Control panel: Power, Master Volume control
- Dimensions: Active speaker: 68mm x 166mm x 94mm | Passive speaker: 68mm x 166mm x 94mm (WxHxD)
- Weight: 0.55Kg (gross)
Only £9.95 inc VAT.
ORDER NOW
Edifier R12U 2.0 Speaker System - Red @ £14.99 inc VAT
Stronger And Richer
Browsing the web for an up and coming star can be frustrating when your computer speakers aren’t loud enough. Edifier’s R12U is here to make your browsing more enjoyable. The USB powered speaker is small enough to travel with you and boisterous enough to hear your videos louder and clearer.
Balanced Sound
As small as they may be they produce a sound twice its size. Designed with a bass reflex port, anything you play through the Edifier speaker is clear and rich.
Effortless Control
With a simple knob, turn your speaker on or off and adjust the volume. All the adjustment you need in a single dial. With the 3.5 mm auxiliary input you can plug in your iPod, tablet, laptop or phone directly to the speaker to play your favorite music. You can even plug in your headphone to Edifier’s R12U for privacy.
Modern Flair
Edifier’s R12U’s unique angle feature drives the sound directly to you, for a better listening experience. Make the USB powered speaker your perfect computer companion. Choose from black, white or red to match your desk décor.
Specifications:
- Total Power Output: RMS 2W x 2(THD+N=10%,F0=1KHz)
- Signal to noise ratio: >85dBA
- THD: <0.5%
- Frequency Response: 30Hz ~ 20KHz(±5dB)
- Input Sensitivity: 700mV ± 50mV
- Input Type: AUX
- Speaker Driver: 21/4 inch (60mmm)
Only £14.99 inc VAT.
ORDER NOW
Edifier R12U 2.0 Speaker System - White @ £14.99 inc VAT
Stronger And Richer
Balanced Sound
Effortless Control
Modern Flair
Specifications:
- THD: <0.5%
- Input Type: AUX
ORDER NOW
Edifier R12U 2.0 Speaker System - Black @ £14.99 inc VAT
Stronger And Richer
Balanced Sound
Effortless Control
Modern Flair
Specifications:
- THD: <0.5%
- Input Type: AUX
ORDER NOW
Edifier Cinesound B7 - RMS 107W with Bluetooth @ £249.95 inc VAT
CineSound B7 is a robust entertainment from a sophisticated home theater system with a Meter long soundbar paired with an 8-inch subwoofer. Comes with a versatile connection includes Bluetooth 4.0 and Optical input along with a Smart standby feature which kicks in after 10 minutes of inactivity.
Home entertainment
Edifier has heighten your home theater experience. Enhancing the B3 soundbar, Edifier has created CineSound B7. Designed for your entertainment needs, B7 Bluetooth soundbar is now accompanied with a subwoofer. It’s time to start watching all those movies on your to-do list.
Amplified sound
Featuring an 8” subwoofer, Edifier’s B7 is introducing you to a new movie theater experience from the comfort of your home. Designed with a 2-¾ inch aluminum diaphragm mid-range and ¾ inch silk dome, your audio will be boasting. Engineered with a tri-amplifying system to expand every sound from your TV or gaming system. Distortion is a thing of the past with the Digital Signal Processing and Dynamic Range Control built-in to CineSound B7.
Thin and sleek
Smooth and slim, the B7 Bluetooth soundbar is designed for elegance and entertainment. Its meter long design incorporates four speaker units and two tweeters for luxurious performance. A built-in smart feature knows when a movie or TV show finishes and after 10 minutes of inactivity sets Edifier’s B7 on standby.
Regulate every sound
Adjust the CineSound B7 to what your ears desire. With built-in controls on the soundbar, easily adjust volume, power and input selection or use the wireless remote. Edifier’s Bluetooth B7 also features three presets. With a simple click your sound is set for watching movies, the news or surround sound.
Multiple connection options
Designed for your home needs, easily connect any device with the versatile options the B7 provides. Its Bluetooth 4.0 capability allows you to connect any device to your speaker. Its 10-meter range lets you place the device anywhere you want without loosing connection. Connect multiple devices at the same time through optical, coaxial, AUX or through 2 RCA analogue audio inputs. You have the freedom to connect your TV and DVD at the same time.
Specifications:
- Total Power Output: RMS 16Wx2(Treble)+19Wx2(Mid-range and bass 75W)
- Signal to Noise Ratio: >85dBA
- Frequency Response: 48Hz~20KHz(±6dB)
- Input Sensitivity: Line in:700±50mV, AUX:550±50mV, AUX:550±50mV
- Input Type: Auxiliary/Line in/Coaxial/Optical/Bluetooth
- Bass Driver: 2 3/4"(700mm)
- Treble Driver: 3/4" (19mm) silk dome tweeter
- Subwoofer Driver: 8" (210mm)
- Speaker Dimensions: 1000x79x80mm
- Box Dimensions: 1085x645x351mm
Only £249.95 inc VAT.
ORDER NOW
Edifier CineSound B3 Soundbar with Bluetooth @ £149.99 inc VAT
3 versatile preset modes (Movie, 3D and News) to satisfy all your audio needs
10-minute smart inactivity standby
Seamlessly connect to your gadgets with Bluetooth 4.0
Wall mount bracket included for hassle-free setup
Unleash your sensations
Edifier's B3 sound bar is loaded with four 70mm speaker units for rich lows and mids, as well as two 19mm tweeters for clear highs. At maximum setting, B3 can unleash 100 dB of room-filling sound. And armed with DSP (Digital Sound Processing), the sound bar is engineered for rock solid performance.
Minimalistic black meets metallic lustre
B3 comes in an elegant, classic black package, while the side panels with brushed finish add a touch of luxury. The control buttons are subtly placed on the side to keep the design clean and simple. A lightweight remote control is also included, so you can adjust the settings from anywhere in the room.
Multiple connections
B3's optical input delivers lossless audio. Coaxial, RCA Line In and auxiliary inputs are also available, so the sound bar can be connect to your TV, game systems, Blu-ray players and other sources at the same time. That means all your favorite entertainment are ready to go, whenever you want, without the hassle of switching wires.
Bluetooth 4.0
B3 is equipped with the improved Bluetooth technology, which provides up to 10 meters of connection. It's faster and more reliable. So you can stream a world of music from your smartphone, tablets and any other Bluetooth-enabled devices, seamlessly.
Specifications:
- Total Power Output: RMS 16W×2(Treble)+19 W×2(Mid-range and bass)
- Frequency Response: 60Hz~20kHz (±6dB)
- Input Sensitivity: Line in:700±50mV, AUX:550±50mV, AUX:550±50mV COA 400mFFs ± 50mFFs
- Bass Driver: 2¾” (70mm)
- Speaker Dimensions: 1000×79×80 mm
- Box Dimensions:1066×170×143mm
ORDER NOW
View our entire Speaker Range - Click Here
Some epic speakers in that range. The edifier stuff I have used has always been really good quality for the money.
Edifier speakers have been one of my most pleasant and surprising purchases of the last 5 years. Glad to see an excellent range at ocuk. Might have to treat myself to a little upgrade :)
My fault wrong link thanks for pointing it out. Lesson learnt to check work.
Should stay at that price for your insolence :o
The sound bars, I'm looking to up the sound of my TV in my bedroom, Mostly used for PS4 or movies, Do we know how decent the B3 is? I'm not looking for WOW CINEMA EFFECT sound, just something to give me bit more character and a little boom.
Not a clue about the soundbar but my TV is hooked up to the cheaper and older version of the new 980Ts and it provides just that - clarity, bass, good range.
For the price they're amazing and I'm quite happy to see even some low end ranges available.
I have not had the pleasure of listening to the soundbar personally but the speakers I have heard are really good.
You can see a little review video here https://m.youtube.com/watch?v=ogTQpFkzb8I.
It is a nice addition to both the PC and console. The B3 and B7 will definitely give your games that extra sound boost and even improve the sound on any movies you watch.
Was just telling my friend how good my Edifier speakers were and came to look if I could pick up a set or two for my living room and kitchen.
Got my eye on the R1280T 2.0 - are they good for the money? All I'd be doing is gaming, listening to music and watching films/TV.
I wonder how good AC/DC - Thunderstruck would sound! :)
They are a good choice, the sound quality is really good and better than you would expect for some £70 speakers. A couple of reviews online which show them in use if you need something else to go off but the videos do not do them justice as the quality is better.
