how do you set custom fan profile in crimson my boys rig needs to be set but cant find the option to set to 60 percent.
The further into Tomb Raider the worse the amount of stutter time becomes, It's no longer playable plus I'm also getting visual errors like this:
https://www.dropbox.com/s/g6qry390xbxl63i/ROTTR 2016-01-31 16-47-29-93.jpg?dl=0
Errors like that are a sign of bad overclocking! Way back on my 7950s I pushed them and I had errors like this in Alan Wake I needed to add more voltage but instead I just lowered my overclock on both memory and Core.
If you have a GPU with 4GB or less dont use Very High Textures this is for 6GB+ cards.. I also noticed AF 16x in this game is very demanding for some strange reason lower this down to 4x or 8x
I wonder if the next set of drivers will have the fix for the core clock bouncing issues
Right guys anyone have a fix for this issue? Iv'e installed the latest Crimson driver after booting into safe mode using DDU to get rid of the old drivers then installed latest crimson drivers. Everything was working fine however ive since done a fresh install of windows 10, installed the crimson drivers again (fresh install no need for DDU)
Ive then installed MSI afterburner and tried to get it to load my overclock profiles which kept black screening me for some reason and had to restart. In the crimson drivers i enabled overdrive? To give the 50% power boost and then the overclocks wouldn't blackscreen me. So thought right back to normal again. I then enabled the option to start MSI on boot and apply overclocks and now i have the issue again blackscreens however it does it right as im loading to desktop right just before it. Ive un-installed MSI Afterburner and that didn't work so then i tried un-installing Crimson drivers and now i can load to desktop fine.
So im guessing Crimson doesn't like MSI Afterburner and overclocking? People having similar issues on the net from googling no fix though.
All the moaning here is with people OCing there cards and that counts for less than 5% of all GPU users.
This game runs great with current drivers if you just leave them alone.
Wait for the fix if you want to start playing with catalyst settings.
People forget that with AMD not having to release a driver update for this game and yet perform better than the competition at higher res with their specific driver update is quite an achievement and a credit to AMD drivers in general.
Since reaching the Siberean base map the entire area is a stutter fest for me.
From what I've read TR runs fine on everything except Fury cards. It's atrocious on them and it's nothing to do with overclocking. So no there's no credit due when there flagship cards aren't working right.
Not a big fan of these Crimson drivers. Which is the last driver that isn't Crimson please?
Same for me on a single 390X, and it has continued after the Siberian map
Actually, I have a 390X and a 5820k and it runs far from well on my system. Lots of stuttering and low framerate problems. You have to remember that pcper tested a very small section at the beginning of the game about 10-15 seconds long which is hardly representative of the performance the user can expect.
It's not just the Fiji cards.
I get severe pausing/stutter in Rise of the Tombraider when textures are set to very high on my 290X and VRAM hits 3.9GB. On High the VRAM usage drops to 3.3GB and everything seems fine. Looks like the game is trying to use more than 4GB on Very High settings.
Hopefully they can fix the issue with drivers since I remember Black Ops 3 did the same on release.
need this driver ASAP, sick and tired of seeing this on 16.1 Crimson. Not sure why GPUz is seeing the driver version as 15.8 as I'm on 16.1 but hey ho. Worst driver ever for crossfire.
