I think you'll find I said "will likely break" not "will definitely break"
Besides, I only read the opening post, from that alone your suggestions looked stupid, and mine seemed reasonable.
I see now that the OP said he is willing to live with 18MPG and doesn't care about anything apart from straight line performance..
Fine, maybe your suggestions make sense. Though you can't get an S4 for £2800. Add £1000 and you'll find a couple. Double it and you might find a good example.
