- 2 Jan 2012
- UK.
I really love the design of the Nano. It appeals to me so much. I'd like to get my hands on one of the white Asus ones, but I don't know that it ever actually got released. I've never seen so much as a picture of a real one in an actual build.
If I get a replacement what's the likelihood the whine will be better? Are these cards particularly prone to it?
They all whine, don't bother! Mine whines too, but it's next to my Xbox One and the Xbox One is louder than the whine and my 6 case fans combined.
So I managed a 1075 core clock.
After looking online it seems other people have similar limit due to the power the card can take.
So I was thinking of eventually water cooling this card to push it further but seems a bit pointless if power is the limit? I do hit 73'C though on some benchmark tests.
I actually managed to squeeze more performance out of the GPU with a similar level power target and volts once under water. On the stock cooler the max I could push the card was 1085 Mhz on the core. Under water I can actually push this further to around the 1130-1140 region. which in the case of Fiji cards is a decent bump.
Could be the VRM's and power phases are getting actively cooler along with more power going to the GPU itself rather then some being diverted to the fan.
Interesting, what cooler did you use?
Well air cooler was just the standard Stock Nano cooler. For the waterblock used one of EK's Nickle R9 Nano waterblocks.
Well you have the holy grail of Nano cards then as I can't even bump up my voltage without it resetting... Managed to get my memory to 535 and GPU to 1065 100% stable under water.
