- 25 Nov 2011
- The KOP
No, 60fps is buttery smooth![]()
Don't know why anyone buys AMD at the moment honestly.
60fps is doable on your settings, when you said other day I run 1080p with texture down to high and AF on 8x I thought you had everything else on max but you dont. AO is set to on and both your shadow setting are on high not very high..
If I want 60fps all i need to do is drop down to 1080p and lower settings nothing to do with AMD or Nvidia when you simpley lowing the quality of the game down.
I run 1440p with almost everything on highest apart from textures on high and AF on 4x with no blur and get 40/50fps my game looks much better.
Edit
Even your level of Detail is on high, set that to very high and get much better render distance
Starting to think it might be something related to the auto saves as it always seems to happen when that happens....
