- 25 Nov 2011
- The KOP
No, 60fps is buttery smooth![]()
Don't know why anyone buys AMD at the moment honestly.
60fps is doable on your settings, when you said other day I run 1080p with texture down to high and AF on 8x I thought you had everything else on max but you dont. AO is set to on and both your shadow setting are on high not very high..
If I want 60fps all i need to do is drop down to 1080p and lower settings nothing to do with AMD or Nvidia when you simpley lowing the quality of the game down.
I run 1440p with almost everything on highest apart from textures on high and AF on 4x with no blur and get 40/50fps my game looks much better.
Edit
Even your level of Detail is on high, set that to very high and get much better render distance
