Ok, so this is a problem that dates back a few years now. I've tried seeking help in the past but either hit dead ends or life got in the way.
Background: I told my parents I could build their new PC for them rather than them buying a Dell or something. Have installed various components (GPU, RAM, storage drives, etc.) in the past so felt I could take this step up. So I got the components, put them in (the first case was awful and I think let to my problems, see below), powered it up and... no (video) output. I tried a couple times to trouble shoot the problem but as I say either hit dead ends or life got in my way. Really, this is my last roll of the dice to get it working before I'll give up and (using a chunk of the money I was saving to replace my gaming PC) buy them a pre-built PC.
So enough waffle. The problem: When I power up everything sounds like it whirls into life (fans, etc.) however there's no video output at all. When the RAM is removed and it's booted up it beeps 3 times (which I believe indicates missing RAM?) but when the keyboard or mouse are unplugged, there are no beeps (which isn't good right?).
From what I can remember; I have tried: Removing everything from the PCIe ports. Removing the mobo battery, waiting a period of time and reinstalling it. I have even tried an old GPU instead of the inbuilt mobo graphics output. Nothing works.
I think the problem is: that the mobo is broken (probably from trying to get it into the original case which was extremely tight and poorly laid out) but I can't confirm this.
What I'd ideally like help on:
I know that is a lot of things and that I'm probably out of luck, but I'd genuinely appreciate any and all help that anyone can offer. Whilst real life stuff has gotten in the way of trying to finish this build, in truth it's sat in the corner of my room for the last couple months with me unable to bring myself to try and finish it as if I can't I don't think I'll be able to bring myself to trying to build my own PC in the future. So, bit cheesy perhaps, but for me this isn't just about finishing (albeit very late!) the PC for my parents, but also about not having to go back to buying pre-built PCs. So yeah, any and all help will be massively appreciated. Specs are below, but if anyone needs any more details, etc. please just ask and I'd be more than happy to provide them as best I can.
Specs:
Again, thanks in advance for any/all help.
- Any other things I can try to get the thing to output something
- Confirmation (or as close to confirmation as can be gotten via a forum) that it's the mobo that's dead
- The components are pretty old (I started this build about 2.5 years ago...) so I expect it's near impossible to buy a replacement mobo? Doesn't have to be the same one, just so long as the CPU fit, etc. If it is a dead mobo and anyone could help find a suitable replacement (in the UK) that would be amazing, otherwise it'll have to be a full new (pre-built) PC
- If it is a dead mobo and I can get a replacement of some description, advise on how best to get the CPU back out (the hint sink and fan have been installed and not sure how to remove them) would be very appreciated
Specs:
- Motherboard: Asrock FM2A75M-DGS A75 Socket FM2 VGA DVI 5.1 Channel Audio mATX Motherboard
- CPU: AMD A10 5800K Black Edition 3.8GHz Socket FM2 4MB L2 Cache
- RAM: 2x Corsair Vengeance 4GB DDR3 1600Mhz CL9 1.5V Non-ECC Unbuffered
- Storage 1: Crucial 64GB M4 SSD2.5" SATA-III
- (Not currently connected) Storage 2: Seagate 1TB Barracuda 3.5" SATA-III Hard Drive 7200RPM
- Power Supply Unit: Powercool 450W
- Optical Drive 1: LiteOn IHOS104 4x BD-ROM SATA Blue-Ray Drive - OEM Black
- Optical Drive 2: Samsung 24x Sata Internal DVDrw Bare Black
- Wireless Card: TP-Link Wireless-N150 PCIe card
