- 13 Jul 2004
- Stanley Hotel, Colorado
AA has been broken for ages in some shape I form. I just use SweetFX for AA now.
Server browser will get more work but there's so many other higher priority things that need doing before that gets more work.
I believe the map bug is fixed for next patch.
Commander? You mean Squad Leader? Hold T, says in the map loading screen![]()
I loaded this up for the first time since a lot of the updates last night and I was absolutely hopeless
I can not make out if players are friendly or not with the new uniforms, I was calling to team mates if I should be able to see tags if they are friendly and the answer was yes, if you don't see a tag shoot them.....bang....team kill
I was an absolute liability..... it took me so long to id enemies that I just got shot even if I got the jump on them
I'm pretty sure we were getting shot at by other friendlies as well but you cant tell if some TK's you only if you TK them is that right?
Its going to take a while to get used to this, damn sneaky enemies wearing similar uniforms to us!
I used to be the same, if they didn't have a nice green or blue tag above their head then they would get shot. But that didn't work as sometimes it wouldn't appear for example if you looked through a hole in the wall or a door. Not I check uniform and map.
If I was a Squad developer I would completely remove the tag and introduce a spy role which wore the same uniform as the team but looked different on the face model.
In real war you don't get a green/blue tag above friendly soldiers! (if there was there would be a lot less deaths!)
I'm new to the game as well, started a round yesterday, saw a guy with no tag above his head and boom. First kill was a TK
Check the map as well to make sure there's no team mates in the direction of fire first was my first lesson.
I'm finding the iron sights really tricky to use as an insurgent. they seem to completely cover the area you're trying to fire at. Apparently I need to learn to use the zoom properly.
In real war you don't get to respawn...
I was all set for a night of Squad yesterday but came home from work to find out the niece and nephew were staying over.
Same tonight.
FML!
Is it pretty easy to join another squad? Or do most people tend to play in the same groups all the time?
Still pondering over this.
Thanks to those that answered my previous questions by the way.
Thanks Swifty. Think I might have to jump on board soon.
Win10 buddy. Never had any issues using SweetFX with any games I've tried![]()
