Budget? Uses?
Budget is around 8k but its flexible, use is just general commuting and travelling around. But thats not really what i asked. Only other car i have my eye on is the newer Mazda 3, but they tend to be more expensive.
Your reply is rather rude mate, he's asking as the 2.2 Dtec lump has a DPF which without the right mileage / use will present you with problems. His question was to give you a helpful reply.
Don't do the mileage - don't bother with a modern diesel.
I believe Honda have moved the DPF right up onto the exhaust manifold so it doesn't suffer from clogging like others do.
The 2.2 diseasel sport Mazda 3's are horrible engines mate, don't bother, I test drove one when I was looking at the Civics and they're far nicer to drive.
Stick with a 2.2 Honda, Type S GT on a early (?)09 plate should get you the better clutch without the DPF.
Or were you looking at much newer?
Aye the one I'm thinking of is the CTDI
