Shall I buy it? For an 18v cordless, Black n Decker,.. bargain? I've checked with Argos who tell me it does come with battery and charger.
http://www.ebay.co.uk/itm/Black-and...671228?hash=item51dc421cbc:g:VSEAAOSwWTRWvKlT
The only thing is it has a plastic chuck, I don't know how much of a problem that might be. Bear in mind, I will probably use it once in a blue moon, so it won't get a lot of usage.
These are answers about the chuck from amazon, where they're selling the same model for £50.
Question: Does it have a locking chuck? i.e can you lock the chuck with one hand?
Answer: No. The chuck twists to grip the drill and so I think it would be very difficult to lock it with one hand.
No, this is not a feature on this drill
Yes, it has a keyless chuck that can be locked by one hand
I think the plastic keyless chuck is the Achilles Heel of this drill. Mine gave way, whilst hand-tightening a 6mm masonry bit, rendering the drill useless. Luckily, Amazon replaced the drill without quibble.
It doesn't lock, especially on masonry bits. This drill is useless for drilling into bricks or concrete as there is no key to tighten the chuck. The bits constantly loosen. It is ok for wood.
