I've been using OpenMediaVault for the past couple of years on my N54L.
Easy to install, easy to setup.
http://www.openmediavault.org/
On mine I'm rocking:-
40GB SSD for OMV, it cost me about 20 quid last year.
4 x 3TB HGST for storage in 2 x Raid 1 arrays.
Transferring to and from my desktop gives me around 80MB/s through my gigabit network.
Did a quick google...
https://tinkertry.com/how-to-change-windows-10-network-type-from-public-to-private
Is it there?
Sorry Stew, gave up in the end and left it running at 4MB/s. Got up this morning to 16% of 606GB completed and it now running at 650kb/s
That can't be right. Do we think it's more likely to be the network or the hard drive?
Will have a dig around at work today and see if I can find a long Cat5 cable, then I'll plug them both into the router directly, no homeplugs.
Although I don't understand why it's at 650kb/s this morning![]()
Doesn't seem great I read and write at ~105MB/s with ZFS on Linux (Same filesystem as FreeNAS)
Well, it's not the read speed of the old drive, just tried transferring from an SSD to the server and it's the same restriction.
So far I have tried
- Disabling “TCP Auto-Tuning”
- Disabling “Large Send Offload (LSO)”
- Disabling IP6
- Set Speed & Duplex to auto in network card properties
- Disabled Windows Firewall
- Disabled Windows Defender
None have made any difference.
have rebooted server and client numerous times.
I'd actually be chuffed if I got 5MB/s back now lol
How many drives do you have in your server?
What drive are you running OMV on?
Can you show me screen shots of the following form the webgui :-
Storage > File Systems
and
Storage > Physical Disks
Cheers
I chatted with David in IRC
[+Davidh2k] i dunno, we always have some guy once in a while that gets really bad transfer rates
[+Davidh2k] he has to run 'iperf -s' <- on the server
[+Davidh2k] and at the other end he has to run 'iperf -d -c HOSTNAMEofSERVER' <- on the client. If the client is a winbox, you can get iperf for windows from here
https://iperf.fr/iperf-download.php
