The problem with Z170 is that there's not much of an upgrade path in the future. If you get an i5-6600k then the i7-6700k is an upgrade option later, but probably not significant enough to warrant the swapout cost (if you think you'll want the 6700k go straight to it now).
Further down the road Z170 options are relatively limited as Skylake-E will use a new chipset and motherboard. Which leaves Kaby Lake, the Skylake refresh. Not much is known about that, but it's probably only incremental upgrades and likely still only quad core. So any significant upgrade from any Z170 system will need a mobo swap.
Btw, SSD is about more than load times. It gets rids of all that system chuntering from the HDD constantly being accessed by Windows for various background tasks, indexing, caching, delayed events etc. All this still goes on of course, but is far less noticeable with a SSD because it happens so much faster so you almost never see the dreaded spinning circle.
As for Lara's hair, she probably dyes it by now anyway (crazy to think it's 20 years since the original Tomb Raider).
