Hi all,
I'm making like a wheeled base for my PC so when I go to the insomnia LAN I don't have to carry it the whole way.
I've bought some of these:
http://www.ebay.co.uk/itm/291110388...49&var=590261473948&ssPageName=STRK:MEBIDX:IT
and an piece of 18mm MDF to attach them too.
I went to Homebase today and got some screws, based on their advice, but I'm not convinced they are suitable for what I need.
These are the screws:
Twin Thread Screw - Bright Zinc Plated - 5 x 20mm - 25 Pack 621392
http://www.homebase.co.uk/en/homeba...right-zinc-plated---5-x-20mm---25-pack-621392
The photo on the website is not accurate, but the head of the screw is the same.
Looking at the screws I've bought there doesn't seem to be a lot of thread on them, so I'm thinking their resistance to being pulled out is not going to be very good. I'm also thinking that the head being angled, but attatching a flat piece of metal to a flat piece of wood is not ideal at all either.
I think I need some screws that have a flat rather than angled head like these:
http://www.homebase.co.uk/en/homeba...right-zinc-plated---6-x-20mm---10-pack-412404
Does anyone think these will be better?
I was also wondering, am I buying screws that are too long? It's 18mm MDF, but 20mm screws. but then the thickness of the metal it's attaching also adds a couple of mm. Is the length of a screw the entire length including the head of it? or just the threaded part?
Sorry for the utter noob questions. The last thing I want is for a wheel to come off when I'm wheeling my PC along on it.
Thanks all,
G
Thanks all,
G
