- 10 May 2012
- North London
Thank you
For those wanting a clean install, download the ISO manually from this page.
http://www.microsoft.com/en-us/software-download/techbench
Make sure you select English International as that is EN-GB. Then write the ISO to a USB stick with rufus because it is blindingly fast if you have USB3.
https://rufus.akeo.ie/
Neowin said:Identified as KB3140743, the update bumps the general release of Windows 10 (version 1511) up to build 10586.122, and it brings a significant range of improvements and fixes:
•Improved reliability in numerous areas, including OS and Windows Update installation, startup, installing and configuring Windows for the first time, authentication, resuming from hibernation, shutdown, kernel, Start menu, storage, Windows Hello, display modes, Miracast, AppLocker, Internet Explorer 11, Microsoft Edge browser, network connectivity and discovery, and File Explorer.
•Improved performance in video thumbnail generation, NetLogon, Windows Store, and standby power consumption.
•Improved support for devices including some wearables, displays, and printer scenarios.
•Reset app default when a registry setting is deleted or corrupted and streamlined notification about the corruption.
•Fixed an issue causing favorites to be lost after updates are installed.
•Fixed several issues that individually could cause certain apps to fail to launch, update, or allow in-app purchases.
•Improved quality of Cortana voices and translations of multiple languages of an Internet Explorer dialog box.
•Improved support for apps, fonts, graphics and display, airplane mode, Group Policy, PowerShell MDM, Windows Journal, Microsoft Edge, printing, touch display, roaming credentials, Push-Button Reset, Windows UX, local and streaming video, audio quality, error reporting, USMT, and VHD creation.
Only just moved from W7 to 10 and obviously it will take some adjusting but how the hell do I turn off that login Windows password so it boots straight to desktop? It's irritating because mines quite a long password.
If I can't remove it and I have to change it I presume it's the windows login for everything, xbox live etc as well?
An update has been released for Windows 10
Source: http://www.neowin.net/news/microsof...2-for-pcs-bringing-huge-range-of-improvements
Maybe this will fix my occasional stratup/shutdown problems on my main PC? Fingers crossed.
Type "Netplwiz" into the search box and open to disable password on logging in. Uncheck the box and enter your password twice...
I still remember when you could make a DVD so as to keep it for reformatting![]()
Thanks Moogleys![]()
Or set a 4 digit pin, that's nice and easy?
This is good program take a look for backup of your HDD .
