 - 10 May 2012
 - North London
If I had any hair left...I would be pulling it out lol
			Well I was thinking of this one for a 27" Freesync
https://www.overclockers.co.uk/aoc-...descreen-led-monitor-black-red-mo-033-ao.html
I find G-sync better.
Which monitors have you tested to come to this conclusion?
 They are both equally as effective at eliminating tearing, juddering and stuttering from the traditional refresh rate and frame rate mismatches. I've seen some fairly good pixel overdrive implementations for both FreeSync and G-SYNC models and also some not so good ones. And if there are any latency differences they're certainly beyond my sensitivity for that sort of thing.No.They are both equally as effective at eliminating tearing, juddering and stuttering from the traditional refresh rate and frame rate mismatches. I've seen some fairly good pixel overdrive implementations for both FreeSync and G-SYNC models and also some not so good ones. And if there are any latency differences they're certainly beyond my sensitivity for that sort of thing.
Even with this post of yours and badass's + anandtech's thoughts being the exact same with "hard evidence" to back up their claims, you will still get the same old coming in with the "gsync is better" line...![]()
You're correct that there are certain features that G-SYNC has and FreeSync lacks at present and it is playing catch-up in that respect. But the overall experience is going to be extremely similar for most users.
For me both technologies worked best at relatively high frame rates and got rid of the traditional issues with even slight drops very nicely. I have tested both technologies extensively and can say that fretting about which technology handles low frame rates is of little consequence when such frame rates feel horribly sluggish and unresponsive on both technologies. I cover this extensively at a subjective level in my reviews, and my thoughts are backed up by others who help with the reviews (they aren't just personal opinion). I can't say I found sudden drops in frame rate more jarring with FreeSync than G-SYNC either. It is possible that G-SYNC does technically handle low frame rates (<30fps or whatever is lower than the refresh rate floor) better, but such low frame rates remain low frame rates. It's not where you want to be on a high refresh rate monitor and no amount of technical wizardry will change that.
But I still think AMD are going about this the right way and Nvidia are... Well... Best leave that kind of discussion in the GPU section.
The latest G-SYNC panels like the Dell have HDMI as well as DP input.
The point of linking to those videos is that there are many aspects that people are glossing over when claiming that G-SYNC isn't any better and as you even admit yourself AMD are playing catch up on some of those aspects.
Yes some of the points of that video "might" still apply but like I said, there has been a lot of updates improving freesync since then and probably likewise for gsync improvements so the test is a bit irrelevant now especially for the area where they test the very low frame rates.
Gsync is better.
