The two things that make the most difference for me are anticipating conditions so you don't use the brakes much and keeping top speeds low.
I'll try the 1st 2nd 6th theory when I go home later... Will report back![]()
WRONG. The distance you have travelled is far further by coasting than you would have achieved otherwise.
I am a "SafEd instructor" (Safe and Fuel Efficient Driving). All new trucks for example automatically switch into neutral to Eco cruise whenever the sensors detect declines.
They also do this just before you crest a hill and use kinetic energy to carry you over the top. This of course means our road speed plunges dramatically.
As far as efficient driving in a car goes then find out your peak torque rpm and always ensure you change up before you reach it, it makes quite a difference.![]()
I've noticed the 15 & 65 plate Scania & Volvos at work do this and tbh the speed drop off isn't too bad ~3mph I'd say, the fuel saving is significantly better, the sensors you refer to in Scanias at least is GPS cruise control, the truck knows when it's on a hill and acts accordingly as it reaches the summit.
 ) and my average economy is the right side of 50 mpg.Also came across fuel consumption curves etc such as http://physics.stackexchange.com/qu...acceleration-minimize-a-cars-fuel-consumption but I'm not entirely sure I understand what it shows.
RPM increases fuel consumption the most.
Pretty much, yes unfortunately. Although a lot of it is down to inconsiderate driving on the part of the truck being overtaken, it's not hard to lift off to let him pass in full knowledge he can subsequently pass later...I wonder if this is contributing to one of the most annoying things I experience on the roads becoming far more common- the 3 mile truck vs truck overtake.
So what will now start happening is truck number 1 with his fancy GPS cruise detects that the crest of a hill is approaching and eases off, truck number 2 who is pinned to his limiter four inches off his back bumper goes out to overtake and when truck number one gets back up to speed is sat there like a lemon mid overtake... Fantastic.
The figure in the above seems to disagree.
Going by my experience not his, if you rev an engine more the injectors are firing more often. When accelerating you need more fuel anyway, so combine that with higher rpm and longer duration in lower gear you use more fuel. I negate this by missing gears on the way up. If you accelerate gently you will go through all gears to achieve the same but drive everyone behind you nuts.
That graph shows gallons per KWH, ie per BHP, once you go higher in rpm your BHP increases so that flattens the line. Using miles would change that graph completely as we use gears to improve the efficiency of the engine.
GPS coast is more of a problem when you've just overtaken another truck, pulled into lane 1 and not realised it has dropped into "eco".
Also ... Wait until that new Scania misreads that truck parked in a layby and slams its brakes full on !
We've had to send ours back to be recalibrated. Now they beep for about 3 seconds before slamming the brakes full on !!
Using a lower gear and less throttle uphill uses more fuel than a higher gear and foot flat on the floor according to fuel consumption instant economy display, that and holding up traffic is why I mainly use hard accel and short shift, often skipping gears if sufficient torque.
Emergency braking system on a Volvo FH.
