Do you have a diesel or petrol? My wild guess would be that the most fuel efficient way to get up a hill would be with the revs near peak torque for your engine - which for diesel would usually be lower down in the rev range than a petrol.
I don't get instantaneous consumption displayed in my car so can't go test what's best for me unfortunately. I usually go for a gear that will require the accelerator to be around 50% depressed.
The adaptive cruise on VAG's is similarly impressive, had some tubbin pull out in front of me and brake on the A34 and the brakes reacted so fast I nearly carped myself!
If every vehicle had a similar system then life would be safer for all of us, assuming the moron behind the wheel engaged it haha.
Truckers have a particularly tough job on the roads with impatient car drivers, so anything that helps them out is good by me.
He means the video of the volvo system, those trucks looked to stop quicker but as he mentions, there is no indication of speed or indeed weight in those videos, so difficult to compare.
I'm sure I could have done it a little more scientifically with a longer hill allowing a larger dataset but it does show that lower RPM higher gear is more fuel efficient
Like a few people have already mentioned, I'd favour using peak torque when accelerating to higher speeds, so if I'm joining a motorway or dual-carriageway, then I'll be using the gears to stay at around 3-4k rpm which is peak torque area for my pathetic little 1.25l engine.
