OK...sounds simple enough
Haha....Freesync not supported
Strange this with a 290x? might be worth reinstalling drivers again then since you didnt have freesync at the time of install.
OK I have this week decided to go to Freesync , got my Crimson drivers installed....but before I hookup my Freesync Monitor is there anything else I have to do please ?
thanx
I heard there was some downclocking issues with Crimson however I just updated from latest Catalyst 15.11.1 beta to latest Crimson drivers, just want to confirm that I don't have that issue?
I was running GTA V to get the stats below and using Sapphire R9 290
When running games like Fifa 16 and Rocket League at 60FPS, the core clock doesn't stay at 1000 but around 700-900, is this normal?best way to check is to use Afterburner or something similar to display the core clock in games. my 390 in games drops as low as 500mhz and then causes me to loose FPS so use afterburner to set it to the default speed
Latest RadeonMod just added a tweak that 'fixes' downclocking. It's a simple reg tweak actually.
http://forums.guru3d.com/showpost.php?p=5240683&postcount=694
I have default settings in OverDrive as I have a fan profile setup in MSI Afterburner however sometimes the Fan Speed option is turned on by itself in the software?
Also my main monitor is detected as Display 2, how do I change it to Display 1?
Will we be getting a game ready driver for The Division/Need for Speed?
Division is already released last week 16.2.1
Anyone got any experience of running crossfire in the Division? Its not running well (slightly below a single card) but that might be a general thing with this driver set as I've been using 15.11 for awhile. Should I be having the core clock issue if overclocking with AB?
